Defining a Stereo Camera in URDF for usage in Gazebo Simulations
Hello all,
I have been struggling for the past few days to get a Gazebo simulation put together, and the hardest part has proven to be getting sensor data integrated in the simulation. I am trying to write a chunk of code that will represent a stereo camera, which seems to launch with no errors, but I'm not seeing any sensor related topics listed below. Can anyone help me sort out the issue?
Thanks in advance!
The relevant section from my URDF is as follows:
<link
name="ZedCamera">
<origin
xyz="-0.015875 1.2526E-17 1.4088E-05"
rpy="0 0 0" />
<mass
value="0.16007" />
<inertia
ixx="0.00039322"
ixy="-3.7717E-21"
ixz="1.1677E-22"
iyy="2.5042E-05"
iyz="-3.0636E-21"
izz="0.00039512" />
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
filename="package://dante_eeTest/meshes/ZedCamera.STL" />
<material
name="">
<color
rgba="0.50196 0.50196 0.50196 1" />
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
<map name="sensor" flag="gazebo">
<verbatim key="zed_camera">
<controller:ros_stereo_camera name="$zed_gz_controller" plugin="libros_stereo_camera.so">
<alwaysOn>true</alwaysOn>
<updateRate>60.0</updateRate>
<leftCamera>l_sensor</leftCamera>
<rightCamera>r_sensor</rightCamera>
<topicName>/raw_stereo</topicName>
<frameName>optical_frame</frameName>
<CxPrime>960</CxPrime>
<Cx>960</Cx>
<Cy>540</Cy>
<focal_length>1.4</focal_length> <!-- image_width / (2*tan(hfov_radian /2)) -->
<distortion_k1>-0.16</distortion_k1>
<distortion_k2>0</distortion_k2>
<distortion_k3>0</distortion_k3>
<distortion_t1>0</distortion_t1>
<distortion_t2>0</distortion_t2>
<baseline>.12</baseline> <!-- home pos. of robot has +x forward, +y left -->
<interface:stereocamera name="zed_iface" />
</controller:ros_stereo_camera>
</verbatim>
</map>
Asked by atomoclast on 2016-08-18 18:11:26 UTC
You're defining physical parameters, but you also need to write plugin to "mock" your own sensor output values, or use existing plugins as @Brosseau.F said in the comment.
Asked by yah130s on 2017-05-17 10:24:49 UTC
I have used stereo cam once but i was not using zed stereo camera. I used camera from gazebo http://gazebosim.org/tutorials?tut=ros_gzplugins and a ros node (stereo_image_proc) to combine the two cameras : http://wiki.ros.org/stereo_image_proc
Asked by Brosseau.F on 2016-08-19 01:24:56 UTC
hi is it possible to to tell me where to get the code for the controller for the stereo camera
Asked by Rajnunes on 2017-05-12 04:31:28 UTC
Hi, did you find solution for this ? Please let me know.
Asked by Sanjana on 2020-07-10 10:11:14 UTC
