How can I control Joint with multi-axis
Hello, I'm creating a simple robot model like pan-tilt camera.
To simulate it, I added 3 links and 2 joints ( revolute ) because I couldn't specify the axis with SetPositionPID() and SetPositionTarget() functions.
But what I really want is to add only 2 links and 1 joint using "revolute2" and control each axes with different PID controllers. Only function what I found was SetJointPosition(), SetJointVelocity() but I couldn't give separated PID controllers to each axes and I'm not sure what kind of controller is controlling the joint in those functions.
How do you control the joint with multi-axes?
Asked by MIBE on 2016-08-23 00:21:44 UTC
Maybe I just found a solution but I didn't test it with revolute2 joint yet.
The solution is to use message named joint_cmd.
As you can see below, I could specify the axis of joint with set_axis() method in msgs::JointCmd class.
           msgs::JointCmd stMsgJointCmd;
    msgs::PID stMsgPID;
    std::string strWheelName = "robot::lwheel_joint";
    stMsgJointCmd.set_axis(0);
    stMsgJointCmd.set_allocated_name(&strWheelName);
    stMsgPID.set_target(100.0);
    stMsgJointCmd.set_allocated_velocity(&stMsgPID);
    m_poJointCmdPub->Publish(stMsgJointCmd);
    stMsgJointCmd.release_name();
    stMsgJointCmd.release_velocity();
I think PID controller for each axes could be specified too, but couldn't confirm it.
Asked by MIBE on 2016-08-24 01:39:49 UTC
