gazebo is not publishing odom tf
Hi all,
I am trying to simulate a car-like robot with following frame tree: frame tree.png. But gazebo is not publishing the tf from odom to base-footprint and I get the following error in the terminal:
[ERROR] [1472202557.517496142, 40.405000000]: Unable to find odometry for model name /=-1
This is what my launch file looks like:
<?xml version="1.0"?>
<launch>
<arg name="use_sim_time" default="true"/>
<arg name="gui" default="false"/>
<arg name="headless" default="false"/>
<arg name="debug" default="false"/>
<param name="use_sim_time" value="true"/>
<arg name="world_name" value="$(find chassis_gazebo)/worlds/chassis.world"/>
<arg name="debug" value="$(arg debug)" />
<arg name="gui" value="$(arg gui)" />
<arg name="paused" value="$(arg paused)"/>
<arg name="use_sim_time" value="$(arg use_sim_time)"/>
<arg name="headless" value="$(arg headless)"/>
<param name="robot_description" command="$(find xacro)/xacro.py '$(find chassis_description)/urdf/chassis.urdf.xacro'" />
<!-- push robot_description to factory and spawn robot in gazebo -->
<node name="chassis_spawn" pkg="gazebo_ros" type="spawn_model" output="screen"
args="-urdf -param robot_description -x 28 -y 4 -z 0 -Y 1.57 -model chassis"/>
<!-- Load joint controller configurations from YAML file to parameter server -->
<rosparam file="$(find chassis_control)/config/chassis_control.yaml" command="load"/>
<!-- load the controllers -->
<node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
output="screen" args="joint1_velocity_controller joint2_velocity_controller front_left_steering_position_controller front_right_steering_position_controller joint_state_controller"/>
<!-- convert joint states to TF transforms for rviz, etc -->
</node>
</launch>
Does anyone have any advice?
Thank you in advance!
Asked by gleb on 2016-08-26 04:27:38 UTC
At your tree doesn't have nothing about odometry.
Asked by tiagosilvadev on 2021-08-01 20:27:10 UTC
Did you ever find a solution to that? I have the exact same problem. In the urdf I use the gazebo_ros_p3d plugin and odom is published but no tf frame.
Asked by flabrosse on 2017-10-24 04:30:56 UTC
