why the model is floating in the air ?
first,i download a model from 3dwarehouse,open the file in the sketchup,import a .dae file.then i use the mese file to make a gazebo model.but sometime i make it.and some model may floating in the air.i also translate the model among z
axis.but it will not be successful,it will still in the initial position .is there anyone can help me?
Asked by whulz on 2016-09-01 04:07:34 UTC
Did you check the model's collisions? Right-click it and choose View->Collisions
Asked by chapulina on 2016-09-01 11:11:31 UTC
Possibilities: Model is set static in the .sdf you have created a fixed joint instead of i.e. a prismatic joint
Asked by Franzisdrak on 2016-09-19 09:58:07 UTC
