joint SetPosition() does not work with pysics enabled
I have a model with two links which are connected with a joint (revolute). At the beginning I have an lower and upper limit, lets say both are zero. I have a model plugin in which I can set the new angle with SetPosition() (upper and lower limit are changed as well). If I run this plugin with physics enabled, the position changes but snaps back to its original position immediately. If I run the plugin with physics disabled, it works just fine.
Any ideas why this is happening?
Thanks
Asked by toblech on 2016-09-01 12:20:55 UTC
