Restitution coefficient does not change
Hi all,
I'm creating a contact simulation of two objects with Gazebo7. I tried to change the restitution coefficient, but still I can't make it.
My URDF code is here:
Ball:
  <link name="ball_link">
  <visual name="ball_visual">
      <origin xyz="$0 0 0" rpy="0 0 0"/>
      <mesh filename="package://single_model/urdf/ball/meshes/ball.dae"/>
         <scale>0.1 0.1 0.1</scale>
  <collision>
      <surface>
         <bounce>
            <restitution_coefficient>0.5</restitution_coefficient>
            <threshold>0.01</threshold>
         </bounce>
      </surface>
    <mass value="${ball_mass}"/>
    <inertia ixx="${ball_ixx}"
             ixy="${ball_ixy}"
             ixz="${ball_ixz}"
             iyy="${ball_iyy}"
             iyz="${ball_iyz}"
             izz="${ball_izz}"/>
Target:
  <link name="target_link">
  <visual name="target_visual">
      <origin xyz="0.0 0.0 0.0" rpy="0 0 0"/>
      <mesh filename="package://single_model/urdf/target/meshes/box.dae"/>
  <collision>
      <surface>
         <bounce>
         </bounce>
      </surface>
    <mass value="${target_mass}"/>
    <inertia ixx="${target_ixx}"
             ixy="${target_ixy}"
             ixz="${target_ixz}"
             iyy="${target_iyy}"
             iyz="${target_iyz}"
             izz="${target_izz}"/>
And gazebo.xacro is here:
Ball:
<gazebo reference="ball_link">
    <selfCollide>true</selfCollide>
    <maxVel>10.0</maxVel>
    <minDepth>0.001</minDepth>
Target:
<gazebo reference="target_link">
When I perform this simulation, both two objects' restitution coefficient are still 0, and they start bounding in the world.
I would really appreciate you if you would give me some advice.
Asked by Mari on 2016-09-07 20:08:41 UTC
urdf? restitution coefficient isn't part of urdf as far as a I know. What happens if you write it directly in SDF? here's an example: https://bitbucket.org/osrf/gazebo_models/src/ca53b7f6b22c2c426c240aa00fb4a8cf23c728d5/frc2016_ball/model.sdf?at=default&fileviewer=file-view-default
you may have to put the restitution_coefficient in a tag
Asked by Peter Mitrano on 2016-09-13 00:04:12 UTC
Thank you very much! I changed my URDF into SDF, then now it works well.
Asked by Mari on 2016-09-15 02:48:51 UTC
