Multimaster gazebo_ros_control plugin causes excessive slowdown
I am attempting to run a robot simulation in a multimaster context. Gazebo runs on one master, the robot's navigation and control processes run on another.
The gazebo_ros_control
plugin runs on the Gazebo master. It is set up in the robot's .xacro file like so:
<gazebo>
<robotNamespace>$(arg robot_namespace)</robotNamespace>
<robotParam>robot_description</robotParam>
If I comment out that plugin, Gazebo runs at a reasonable rate. Note that the launch file to spawn the robot is included from within a <group ns="$(arg robot_namespace">
tag. gazebo_ros_pkgs
is built from source, kinetic-devel branch
Possibly of note: to prevent a consistent Gazebo crash which occurred every time the controllers were spawned ("[/gazebo]: Could not find parameter robotdescription on parameter server"), there is both a `robotdescriptionand a
robotname/robotdescription` param on the Gazebo master parameter server. However, the slowdown is encountered with or without this unfortunate hack.
On the robot master, we have a controller manager spawner
node, launched like so:
<rosparam command="load" file="$(find rzr_control)/config/rzr_control.yaml" />
<node name="base_controller_spawner" pkg="controller_manager" type="spawner"
args="rzr_joint_publisher rzr_lift_controller rzr_velocity_controller
--shutdown-timeout 1
--timeout 300
--namespace /sim/$(arg robot_name)"/>
(a 300 second timeout may seem excessive, but is required because Gazebo is running so slowly. It takes a very long time to actually advertise the mutlimaster-relayed topics)
The launch file by which basecontrollerspawner is spun up is included with a ns=$(arg robot_namespace)
argument in the
gz stats
output the following with the current configuration:
administrator@vm-jliviero-trusty-ws:~/ws$ gz stats
Factor[0.00] SimTime[1.70] RealTime[253.26] Paused[F]
Factor[0.00] SimTime[1.71] RealTime[256.12] Paused[F]
Factor[0.00] SimTime[1.72] RealTime[259.05] Paused[F]
Factor[0.00] SimTime[1.73] RealTime[261.86] Paused[F]
...etc
In a single-master context, Gazebo works as expected - there is no significant slowdown of the real-time factor.
We are using Gazebo 7 and ROS Indigo.
Is there anything obvious or missing that would cause Gazebo to drag in this way?
Asked by JLiviero on 2016-09-14 20:33:22 UTC
