<gazebo reference=""> not loaded from urdf.xacro Gazebo6
Hello Everyone,
Using Gazebo6.6, Ros Indigo.
I am using a .xacro to generate my model spawn it via the spawn model plugin.
Lately i was trying to change the colors of my vehicle in the simulation. But for some reason none of my tries resulted in a change of color in my simulation. I definied a reference for each link but still no results.
Here is how i load the gazebo tag:
<gazebo reference="wheel_f_l">
<script>Gazebo/Black</script>
Even with:
<material>Gazebo/Black</material>
it doesn't work. Though setting the colors for visualization via rgba in Rviz works. Did anybody experience sth. similar. It should work, because i saw many examples on github etc. Did i miss something? Help would be very appriciated.
EDIT: some of my launch file
<launch>
<!-- start gazebo server-->
<node name="gazebo" pkg="gazebo_ros" type="gzserver" respawn="false" output="screen" args="$(arg command_arg1) $(arg world_name) --verbose" />
<!-- load vehicle description to the parameter server -->
<param name="robot_description" command="$(find xacro)/xacro.py '$(arg robot_model)' tf_prefix:='$(arg tf_prefix)' ns:='$(arg robot_ns)'" />
<group ns="$(arg robot_ns)">
<!-- spawn vehicle model in gazebo -->
<node name="spawn_robot_model" pkg="gazebo_ros" type="spawn_model"
args="-param robot_description
-urdf
-x $(arg pos_x)
-y $(arg pos_y)
-z $(arg pos_z)
-Y $(arg yaw)
-model $(arg robot_name)"
respawn="false" output="screen"/>
</launch>
Asked by Franzisdrak on 2016-09-26 04:59:55 UTC
The following code works for me:
<visual>
<script>
<name>Gazebo/Black</name>
</script>
<emissive>0 0 0 1</emissive>
Asked by nzlz on 2016-09-26 05:38:03 UTC
Tried it without success. Do you include the gazebo references at the end of your xacro or do you load them via a second file which you include at the beginning?
Asked by Franzisdrak on 2016-09-26 07:35:20 UTC
The URDF I tested is the following: https://gist.github.com/Nestor94Gonzalez/877adf2b7e63dda66ad0f3bc7f02096a . I just place that code before the final tag. Make sure you see 'wheel_f_l' as a model link in gazebo (some links are not visible in gazebo when using urdf). If the problem is the uri, you can replace the script part with this code: https://gist.github.com/Nestor94Gonzalez/54c7af6f134e2072d304e316d4ea9d88
Asked by nzlz on 2016-09-26 08:21:59 UTC
My filepath to the gazebo default materials was different. Didnt find where the default material are on my setup but i will try with replacing the script part with what you sent. Ty so far!
Asked by Franzisdrak on 2016-09-26 09:24:07 UTC
wont work :/
Asked by Franzisdrak on 2016-09-26 09:29:25 UTC
Can you share your URDF file?
Asked by nzlz on 2016-09-26 10:12:59 UTC
@Nestor94Gonzalez What version of Gazebo did you get this working with? I'm using Gazebo7/Kinetic and my URDF's also show up white. I believe it is happening at the step where Gazebo converts the UDRF to SDF (gz sdf -p model.urdf). I'm wondering if this is a bug in Gazebo/SDF...
Asked by plusk01 on 2017-01-05 01:04:10 UTC
