Gazebo crashes when attempting to create link
Hi all, I'm new to Gazebo and I was following the tutorial here: Model Editor Tutorial
As I was attempting to create the second link for the "copied wheel", the gazebo crashed. Then when I restarted, I was able to reload the model and I attempted to edit the link but some of the options were missing like "Align links". So I tried to delete the link and gazebo crashed again. I tried multiple times to redo this but no luck. Creating a new link eventually crashes. I'm running on Ubuntu 16.04 and running version Gazebo multi-robot simulator, version 7.4.0 . I've attached what I think is the relevant log but I'm not sure what state it is in since Gazebo crashed while I was recording it.
Any ideas here?C:\fakepath\gazebo.crash.log.yaml
Asked by TheGBiv on 2016-10-18 20:45:03 UTC
you're missing the log
Asked by Peter Mitrano on 2016-10-18 22:36:41 UTC
Dang! Rookie mistake. However, I was unable to upload it directly because the uploader doesn't accept the "*.log" file extension. I just named it ".yaml", closest thing to xml...
Asked by TheGBiv on 2016-10-19 04:40:21 UTC
Any ideas here? I'm still stuck on this.I believe I uploaded the log correctly. If not please advise on what info is needed to diagnose the issue
Asked by TheGBiv on 2016-10-28 05:37:48 UTC
Can you run Gazebo in verbose mode and update your question with any errors that get printed?
Asked by chapulina on 2016-10-28 12:45:45 UTC
