gazebo_ros_vacuum_gripper not working as expected
Hello there,
I am trying to use the gazeborosvacuumgripper plugin from gazeborospkgs in Jade. My URDF can be found here. Basically it is a box that starts out roughly 0.5 m above ground and then gravity pulls it downward. On the underside of my box, I have added a link/joint for the vacuumgripper.
I am able to turn the grasping service on and it notifies me on the topic /Gecko_2/vacuum_gripper
that it is grasping. However, if I apply a body force in Gazebo that is just larger than the weight of the box, the box moves upward off the ground plane in Gazebo. When this occurs, the state of /Gecko_2/vacuum_gripper
stays True
(grasping).
This should not happen from my understanding of the vacuum_gripper. Is there something I am doing wrong?
I want to be able to extend this example to a walking robot in which each leg will be attached to the groundplane through a vacuumgripper.
Any help would be appreciated, including going about this a different way. I looked into gazebo/physics/gripper.cc, but have not yet tried. It appears to create a fixedJoint between the gripper and the grasping object for a certain amount of time.
Asked by JoshMarino on 2016-10-26 08:45:41 UTC
After going through the C++ code, I was able to determine that the force is being added properly to the link.
Still not sure why I am able to apply an additional body force in Gazebo (that is more than the weight of the box, but less than weight of box + vacuum force), and the box lifts off the ground.
Asked by JoshMarino on 2016-10-28 16:40:16 UTC
I'm faced the same problem. Do you know what's the detailed meaning of the argument: maxDistance and min Distance in block? Thank a lot!
Asked by NickelCao on 2019-04-19 02:01:31 UTC
