Mobile Robot in gazebo using URDF files instead of SDF, the wheels are disappearing
I am trying to create a mobile robot using urdf and following the tutorial "Gazebo : Tutorial : Make a Mobile Robot" that creates SDF file. In my case I changed the size of the robot and I am creating it using URDF. I did the following: 1- I created a file called mobileRobot.urdf.xacro
<?xml version="1.0"?>
<robot name="my_robot" xmlns:xacro="http://www.ros.org/wiki/xacro">
<xacro:include filename="$(find my_robot_description)/urdf/my_robot.gazebo" />
<xacro:include filename="$(find my_robot_description)/urdf/my_robot.xacro" />
</robot>
2- I created another file called my_robot.xacro
<robot xmlns:xacro="http://www.ros.org/wiki/xacro">
<property name="pi" value="3.1415926535897931" />
<link name="base_link" >
<inertial> <mass value="0.5"/>
<inertia ixx="0.005395" ixy="0.0" ixz="0.0" iyy="0.005395" iyz="0.0" izz ="0.007470"/>
<box size="0.3 0.3 0.2" />
<box size="0.3 0.3 0.2"/>
<material name="blue"> </material>
<link name="left_wheel">
<collision>
<origin xyz="0.0 0.18 -0.1" rpy="0 1.5707 1.5707" />
<cylinder radius=".1" length=".05"/>
<visual>
<link name="right_wheel">
<collision>
<origin xyz="0.0 -0.18 -0.1" rpy="0 1.5707 1.5707" />
<visual>
<joint type="revolute" name="right_wheel_hinge">
<limit effort="30" velocity="1.0" lower="-2.792526" upper="2.792526"/>
<origin xyz="0 0 0.03" rpy="0 0 0" />
<child link="right_wheel"/>
<parent link="base_link"/>
<axis xyz="0 1 0"/>
<joint type="revolute" name="left_wheel_hinge">
<!--<limit effort="30" velocity="1.0" lower="-2.792526" upper="2.792526"/>-->
<child link="left_wheel"/>
<dynamics damping="0.7"/>
<axis xyz="0 1 0"/>
</robot>
3- File my_robot.gazebo
<robot>
<!-- ros_control plugin -->
<gazebo>
<robotNamespace>/My_ROBOT</robotNamespace>
<!-- base_link -->
<selfCollide>true</selfCollide>
<gravity>true</gravity>
</robot>
Finally I created a launch file
<?xml version='1.0'?>
<launch>
<arg name="model" default="$(find my_robot_description)/robots/mobileRobot.urdf.xacro"/>
<param name="robot_description" command="$(find xacro)/xacro.py $(arg model)" />
<include file="$(find gazebo_ros)/launch/empty_world.launch"> <arg name="use_sim_time" value="true"/></include>
<node name="Robot1" pkg="gazebo_ros" type="spawn_model"
args="-x 2.0 -unpause -urdf -model robot1 -param robot_description" respawn="false" output="screen" />
<!--<node name="Robot2" pkg="gazebo_ros" type="spawn_model"
args="-x 3.0 -unpause -urdf -model robot2 -param robot_description" respawn="false" output="screen" />
<node pkg="robot_state_publisher" type="robot_state_publisher" name="robot_state_publisher">
<param name="publish_frequency" type="double" value="30.0" />
</node>
<node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher" />
</launch>
1- When I run the launch file I cant see the wheels of the robots in gazebo. but If I changed the wheels to type fixed I can see the wheels. I want the type of the wheels to be revolute what should I do exatcly to see it in gazebo ?
2- Also, what is the tag property to convert from
3- Moreover, if the size of the box mobile robot is 0.3 0.3 0.2 are the links (left and right wheels) and joint's position, visual and geometry I created for this size are acceptable ?
4- If I want to control this robot using keyboard, what should I do to make this robot publish and subscribe topics to connect it with ROS ?
Thanks in advance
Asked by RSA on 2016-10-28 01:37:43 UTC
I think you have to give inertial values for the wheels too..
Asked by rukn on 2018-07-10 07:09:59 UTC
1) When I run the launch file I cant see the wheels of the robots in gazebo. but If I changed the wheels to type fixed I can see the wheels.
@rukn's answer is good.
- Give your wheel realistic approximate inertial values. See: https://en.wikipedia.org/wiki/List_of_moments_of_inertia
- Start gazebo in paused mode, then advance the simulation in single time steps. This will help you figure out what is causing the model to fly apart.
2) Also, what is the tag property to convert from
false (this one in SDF) from SDF to xacro ?
Sorry, I don't understand what you are asking here. Please rephrase your question.
3) Moreover, if the size of the box mobile robot is 0.3 0.3 0.2 are the links (left and right wheels) and joint's position, visual and geometry I created for this size are acceptable ?
It depends on what you're trying to simulate and what you are using the simulation for. You want your simulation to match either a real robot or a planned robot as closely as possible.
- If your focus is physical interactions, then it's important to get the collision elements right (link masses, inertial matrices, etc...).
- Whereas if your focus is image processing/object recognition, then you can "fake" the physics - really you're faking the fake physics - but you'll need to have really good visual elements (colors, textures, meshes, etc...).
4) If I want to control this robot using keyboard, what should I do to make this robot publish and subscribe topics to connect it with ROS ?
You can:
- Use Differential Drive or Skid Steering Drive Gazebo Plugins
- Write your own Gazebo Plugin. See the Velodyne Control plugin tutorial.
- Use ros_control.
Asked by josephcoombe on 2018-07-10 09:08:05 UTC
sorry, I'm too lazy to check it myself. Wheels are disappearing from where? the URDF or corresponding sdf file? or Gazebo?
Asked by eugene-katsevman on 2017-04-11 10:08:11 UTC
