GZWeb deploy hangs generating thumbnails
When running deploy -t, the first folder's thumbnails are generated, and it hangs almost immediately on the second folder with the following, and never comes back (I have to CTRL-C):
Warning [parser.cc:340] Converting a deprecated source[/home/sitl/gzweb/tools/../http/client/assets/arm_part/model.sdf].
Warning [Converter.cc:59] Version[1.6] to Version[1.4]
Please use the gzsdf tool to update your SDF files.
$ gzsdf convert [sdf_file]
Error [Converter.cc:127] Unable to convert from SDF version 1.6 to 1.4
Msg Waiting for master
Msg Publicized address: 10.2.222.41
Error [Node.cc:90] No namespace found
I have tried running the gzsdf tool as it suggests and still get:
This is preventing me from being able to successfully install gzweb (at least usefully).
Asked by srees on 2016-10-28 07:01:13 UTC
Since there are LOTS of folders in here and the error occurs on a large number of them, I'm looking for a better solution than hand-modifying every single model.sdf and model.config...
Asked by srees on 2016-10-28 07:04:01 UTC
normally the sdf conversion tool will try convert the model to a higher (current) sdf version but it appears you're using sdf 1.4 which is older than the version of the model.sdf file (1.6). Maybe try taking out the
arm_part
model from thehttp/client/assets
folder first and see if the sdf conversion error is what's causing the process to hang?Asked by iche033 on 2016-10-28 12:13:49 UTC
I'm also wondering if it's an issue with gazebo being version 2 in this particular case...I don't recall this issue on our other gazebo 6 installations.
Asked by srees on 2016-10-28 12:33:19 UTC
