Gazebo Block Laser - Avoid Collision with floor
Is there a way to avoid collision with the floor plane?
Asked by soulslicer on 2016-10-30 10:30:12 UTC
Are you trying to prevent the laser range finder from returning values for the floor plane? If you are using the GPU laser sensor, then you can disable the ground plane visual element to achieve this result.
Asked by nkoenig on 2016-10-31 09:48:39 UTC
How do I do that? I need it to be visible in my cameras though
Asked by soulslicer on 2016-11-01 10:33:02 UTC
