animated box always move
I followed the animated box tutorial and everything works fine.
Then I tried to go further to control the movement of the box but I found it does not work.
For example, I wrote
key = this->anim->CreateKeyFrame(30.0);
key->Translation(ignition::math::Vector3d(0.0, 10.0, 10.0));
key->Rotation(ignition::math::Quaterniond(0.0, 0.0, 0.0));
key = this->anim->CreateKeyFrame(160.0);
That means I want the box will be static between 00:30:00 - 02:40:00. However the box continues to move, slowly but steady. I comment out nearly all parameters in .world file but everything remains the same.
Is there anyone know why this happen and how to fix that problem?
Asked by xxie on 2016-11-02 19:15:15 UTC
