Why does gazebo contact sensor topic stops publishing on deleting and respawning the object to whch the contact sensor is atached?
asked 2016-11-11 05:45:48 -0500
SP gravatar image
updated 2016-11-11 05:49:53 -0500
I have a box object model to which I have attached a contact sensor, following this tutorial. On spawning the object in gazebo, initially I get the contact sensor data on the topic /gazebo/default/blue_box1/link/my_contact. However, when I delete this object and re-spawn it, no data is published on this topic, and I just get the following
> Msg Waiting for master Msg Connected
> to gazebo master @
> http://127.0.0.1:11345 Msg Publicized
> address: 192.168.5.30
Please help me in debugging this issue. I have already added the update rate in the sensor, so that may not be the cause. Thanks.
answered 2016-11-11 07:49:48 -0500
nkoenig gravatar image
This problem may have been resolved with this pull request. You can try compiling gazebo from source, using the gazebo7 branch, or wait for a new gazebo7 debian release.
Thank you; previously I was using Gazebo 2 which comes with ROS Indigo. I integrated ROS Indigo with Gazebo7, and now this problem seems to be resolved.
SP gravatar imageSP ( 2016-11-21 05:32:25 -0500 )edit
answered 2018-02-14 15:24:21 -0500
lakehanne gravatar image
FYI, this problem still persists on Gazebo 8
Asked: 2016-11-11 05:45:48 -0500
Seen: 326 times
Last updated: Feb 14 '18
