updating new question of gazebo errors
Hi to all, I'm working with the latest version of gazebo. As I've keep some work from a coworker who was working with the gazebo's next-to-last version I've got an error when I'm trying to launch gazebo's world:
Error [parser.cc:581] Unable to find uri [model://chess_pattern]
Does anyone know how to solve it?
Thanks for all,
JĂșlia
Asked by juliamp on 2016-11-11 12:10:13 UTC
When you refer to a model using model://, Gazebo searches for it within the paths defined in the environment variable GAZEBO_MODEL_PATH. You can do env | grep "GAZEBO" to check if you have any paths defined.
If the path is not there, you can set it as follows. Considering that your model's directory is /path/chess_pattern:
export GAZEBO_MODEL_PATH=/path:$GAZEBO_MODEL_PATH
Note that this only works for the current shell (terminal). You can add that line to your ~/.bashrc file so it works for every new terminal.
Asked by chapulina on 2016-11-11 16:26:15 UTC
