Seg Fault from Controller Spawner couldn't reach controller_manager to take down controllers.
asked 2016-11-29 20:42:42 -0600
sauronalexander gravatar image
updated 2016-11-30 11:06:43 -0600
nkoenig gravatar image
Hello there, I have encountered troubles when launching controllers, especially joint_trajectory_controller. I got the following log from the terminal:
[INFO] [WallTime: 1480474127.896390] [5.150000] Controller Spawner: Loaded controllers: left_leg_controller, right_leg_controller, head_controller, left_arm_controller, right_arm_controller
  File "/opt/ros/indigo/lib/controller_manager/spawner", line 212, in <module>
    if __name__ == '__main__': main()
  File "/opt/ros/indigo/lib/controller_manager/spawner", line 204, in main
    resp = switch_controller(loaded, [], 2)
  File "/opt/ros/indigo/lib/python2.7/dist-packages/rospy/impl/tcpros_service.py", line 435, in __call__
    return self.call(*args, **kwds)
  File "/opt/ros/indigo/lib/python2.7/dist-packages/rospy/impl/tcpros_service.py", line 525, in call
    raise ServiceException("transport error completing service call: %s"%(str(e)))
**rospy.service.ServiceException: transport error completing service call: unable to receive data from sender, check sender's logs for details**
[INFO] [WallTime: 1480474129.103476] [5.157000] Shutting down spawner. Stopping and unloading controllers...
[gazebo-1] process has died [pid 21849, exit code 139, cmd /home/viki/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/scripts/gzserver -e ode /home/viki/catkin_ws/src/reemc_robot/reemc_simulation/reemc_gazebo/worlds/empty.world __name:=gazebo __log:=/home/viki/.ros/log/aba3bd78-b6a4-11e6-9191-080027b46cdd/gazebo-1.log].
log file: /home/viki/.ros/log/aba3bd78-b6a4-11e6-9191-080027b46cdd/gazebo-1*.log
**[WARN] [WallTime: 1480474160.106558] [5.157000] Controller Spawner couldn't reach controller_manager to take down controllers. Waited for 30 second(s).**
[joint_trajectory_controllers_spawner-3] process has died [pid 21862, exit code 1, cmd /opt/ros/indigo/lib/controller_manager/spawner left_leg_controller right_leg_controller head_controller left_arm_controller right_arm_controller __name:=joint_trajectory_controllers_spawner __log:=/home/viki/.ros/log/aba3bd78-b6a4-11e6-9191-080027b46cdd/joint_trajectory_controllers_spawner-3.log].
log file: /home/viki/.ros/log/aba3bd78-b6a4-11e6-9191-080027b46cdd/joint_trajectory_controllers_spawner-3*.log
^C[head_controller/point_head_action-4] killing on exit
[gazebo_gui-2] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
Can anyone figure what might be the problem of this issue? I am using Gazebo7 and ROS Indigo. Thank you very much!
This looks like a problem with ROS. You should try asking this question on answers.ros.org.
nkoenig gravatar imagenkoenig ( 2016-11-30 11:07:37 -0600 )edit
So this has nothing to do with Gazebo? Coz I don't really understand how controllers are loaded and spawned. It seems that the issue behind everything is controller manager. Thanks anyway.
sauronalexander gravatar imagesauronalexander ( 2016-11-30 13:13:46 -0600 )edit
As far as I can tell, this has nothing to do with Gazebo.
nkoenig gravatar imagenkoenig ( 2016-11-30 14:23:59 -0600 )edit
I have checked the code of spawner, it seems that the error has something to do with gazebo. So the ros service is offered by gazebo and the request to the gazebo is made correctly. Only the response from gazebo is wrong. It seems the issues is that the controllers cannot be started in gazebo.
sauronalexander gravatar imagesauronalexander ( 2016-12-01 15:41:39 -0600 )edit
answered 2016-12-06 22:39:00 -0600
Reinstalling the ros solves the entire problem.
Asked: 2016-11-29 20:42:42 -0600
Seen: 568 times
Last updated: Dec 06 '16
