Correct way to format URDF for 6 DOF between base_link and robot_arm_base_link using JointTrajectoryController
Hello Gazebo Users,
What is the proper way to write a URDF in order to create a base_link that has 6 DOF and then attach a pair of robot arms to the underside? I would be doing this to create a walking robot. I would like to have the 6 DOF together under one controller using a JointTrajectoryController, as well one controller for each robot arm with a JointTrajectoryController.
I have tried so far creating a baselink using a cube, then connecting 6 other very small links with the 6 DOF required (3 prismatic and 3 revolute). I then tried connecting the base link of the robot arm to the 3rd revolute link. However, when I did this, the robot arm fell through the baselink (cube) and landed on the ground.
Any help would be appreciated.
Asked by JoshMarino on 2016-12-14 14:19:38 UTC
