wheels move by themselves
So I made this simple two-wheel with a chassis robot in urdf. Then I ran it with roslaunch in gazebo, and found the wheels moving slowly by itself. I could see velocity and effort in axis1 of their joints set to -1. What's the problem here? Do you see the same behavior? or just my machine?
model.urdf: link alphbot.launch: link alphbot.world: link
EDIT: I'm using gazebo version 7.4.0 and ROS Kinetic and, (might not be relevant), running this in catkin workspace.
Asked by mixs222 on 2016-12-17 17:44:26 UTC
One reason could be that your model starts the simulation inside the ground, so the first thing the simulation does is pushing it up strongly, and the robot might get some small velocity from that. Try spawning it in a higher position.
But in any case, to avoid drifting even further, you might need to configure surface properties a bit more, which is not trivial.
Asked by chapulina on 2016-12-19 11:39:55 UTC
I've tried spawning at z=0.1, 0.2, 1, 5, and 10 but it still behaved the same. I added
Asked by mixs222 on 2016-12-19 18:40:37 UTC
Have you tried setting static joint friction for the wheel joints? This should stop them from responding to little torques coming from little calculation errors.
Asked by eugene-katsevman on 2017-04-11 10:01:27 UTC
