How to do Swarm robots in ROS-gazebo ?
Hi, I am doing swarm robots simulation on ros gazebo(ros indigo, Gazebo7, ubuntu 14.04). I want to use 802.11 wifi card in robot. is it available in gazebo or in ROS? I found WirelessTranmitter and WirelessReceiver files in bitbucket but I think it will not be useful. as every robot should transmit and receive signals.
Is there any other idea that i can make communnication between robots and get the RSSI(received signal strength indicator) value and calculate the distance between the robots and then i want to disperse the robots.
Asked by brijesh on 2016-12-21 02:32:11 UTC
had you consider running multiple VM with ros and gazebo ,each one with a robot that communicates trough the network.You can use Matlab or other software to fake the wifi in the communication protocol
Asked by wilmer on 2016-12-29 06:24:38 UTC
