Computing Joint Rotations Using KDL
I am trying to use the Kinematic Dynamics Library (KDL) within Gazebo to make a "robot arm" position it's palm onto a cylinder. My current issue is that when I rotate my joints to the computed values, my robot is not at all where I expect it to be and does not touch the target cylinder. Pasted below is the relevant code from my plugin
//Create a KDL Joint Chain of our Arm Robot
KDL::Chain chain;
//Base Joint
math::Vector3 basePose = mBaseJoint->GetAnchor(0);
chain.addSegment(KDL::Segment(KDL::Joint(KDL::Joint::RotZ),
KDL::Frame(KDL::Vector(basePose.x, basePose.y, basePose.z))));
//Shoulder Joint
math::Vector3 shoulderPose = mShoulderJoint->GetAnchor(0);
chain.addSegment(KDL::Segment(KDL::Joint(KDL::Joint::RotX),
KDL::Frame(KDL::Vector(shoulderPose.x, shoulderPose.y, shoulderPose.z))));
//First Elbow Joint
math::Vector3 firstElbowPose = mFirstElbowJoint->GetAnchor(0);
KDL::Frame(KDL::Vector(firstElbowPose.x, firstElbowPose.y, firstElbowPose.z))));
//Second Elbow Joint
math::Vector3 secondElbowPose = mSecondElbowJoint->GetAnchor(0);
KDL::Frame(KDL::Vector(secondElbowPose.x, secondElbowPose.y, secondElbowPose.z))));
//End Joint
math::Vector3 endPose = mWristJoint->GetAnchor(0);
chain.addSegment(KDL::Segment(KDL::Joint(KDL::Joint::None),
KDL::Frame(KDL::Vector(endPose.x, endPose.y, endPose.z))));
KDL::ChainIkSolverPos_LMA myIk = KDL::ChainIkSolverPos_LMA(chain);
//Create joint array
jointCount = chain.getNrOfJoints();
KDL::JntArray jointPositions = KDL::JntArray(jointCount);
targetRotation = KDL::JntArray( jointCount );
for(int i = 0; i < jointCount - 1; i++)
jointPositions(i) = mJoints[i]->GetAngle(0).Radian();
physics::ModelPtr target = mModel->GetWorld()->GetModel("Target");
math::Pose pose = target->GetWorldPose();
math::Pose myPose = mModel->GetWorldPose();
double xPosition = pose.pos.x - myPose.pos.x;
double yPosition = pose.pos.y - myPose.pos.y;
double zPosition = pose.pos.z - myPose.pos.z;
KDL::Frame cartesianPosition = KDL::Frame(KDL::Vector(xPosition, yPosition, zPosition));
gzdbg << "Calculating..." << std::endl;
bool kinematics_status;
kinematics_status = myIk.CartToJnt( jointPositions, cartesianPosition, targetRotation );
gzdbg << "Final Status: " << kinematics_status << std::endl;
if(kinematics_status >= 0)
for( int i = 0; i < jointCount - 1; i++ )
mJoints[i]->SetAngle(0, targetRotation(i));
}//Create a KDL Joint Chain of our Arm Robot
KDL::Chain chain;
//Base Joint
//Shoulder Joint
//First Elbow Joint
//End Joint
Any help on the issue would be very appreciated.
Asked by chrismflynn on 2013-02-24 18:47:03 UTC
Is the robot model in the wrong position, or do the joints end up in the wrong configuration?
Asked by nkoenig on 2013-03-07 23:32:55 UTC
The joints end up in the wrong configuration. I ended up doing a custom solution since I could reduce my joint rotation to a 2 dimensional problem.
Asked by chrismflynn on 2013-03-13 11:35:36 UTC
