Gazebo7 IMU plugin - No TF between base_link and imu_link
My environment is Ubuntu 16.04, running Gazebo7 with ROS Kinetic.
The following gazebo imu plugin is configured using via a xacro. The xacro also uses the diff drive controller plugin. Everything loads well, except I cannot see the TF between baselink and imulink via viewframes or tfmonitor. I do however see the the the TF between the wheels and base_link. Am I missing something? The same xacro works well in Gazebo 2.2.3 and ROS indigo.
  <gazebo>
    <plugin name="imu_controller" filename="libgazebo_ros_imu.so">
      <alwaysOn>true</alwaysOn>
      <updateRate>30</updateRate>
      <bodyName>imu_link</bodyName>   <!--imu_link -->
      <topicName>imu/data</topicName>
    <serviceName>imu/is_calibrated</serviceName>
      <gaussianNoise>0.1</gaussianNoise>
    <xyzOffsets>0 0 0</xyzOffsets>
    <rpyOffsets>0 0 0</rpyOffsets>
tf_monitor output:
Frames:
Frame: base_link published by unknown_publisher Average Delay: 0.000166667 Max Delay: 0.001
Frame: left_front_wheel_link published by unknown_publisher Average Delay: 0 Max Delay: 0
Frame: left_rear_wheel_link published by unknown_publisher Average Delay: 0 Max Delay: 0
Frame: right_front_wheel_link published by unknown_publisher Average Delay: 0 Max Delay: 0
Frame: right_rear_wheel_link published by unknown_publisher Average Delay: 0 Max Delay: 0
All Broadcasters:
Node: unknown_publisher 41.365 Hz, Average Delay: 0.000125 Max Delay: 0.001
Asked by bluehash on 2017-01-04 09:12:03 UTC
The issue was probably an update to view_frames in ROS.
I've posted a temp workaround here.
Asked by bluehash on 2017-01-04 11:03:40 UTC
