cmd_vel not working with custom plugin
Hi, i wrote a plugin(attached down) to move a robot in the space , i compile the plugin and is compiling ok.
I add this line to my SDF at the end of model
  <plugin name="plugins" filename="libplugins.so"/>
i am running the command
rostopic pub /src/wilmer_gazebo/cmd_vel geometry_msgs/Twist "linear:
 x: 0.1
 y: 0.0
 z: 0.0
angular:
x: 0.0
y: 0.0
z: 0.3"
publishing and latching message. Press ctrl-C to terminate
when i run echo i dont get any return
WARNING: no messages received and simulated time is active
i run nodegraph and i get this image description
there is no connection between nodes...how can i solve this?
EDIT I change my cmdvel to rostopic pub cmdvel geometry_msgs/Twist "linear: x: 0.1 y: 0.0 z: 0.0 angular: x: 0.0 y: 0.0 z: 0.3" the run rostopic list and get:
 /clock
 /gazebo/link_states
 /gazebo/model_states
 /gazebo/parameter_descriptions
 /gazebo/parameter_updates
 /gazebo/set_link_state
 /gazebo/set_model_state
 /rosout
 /rosout_agg
 /wcmd_vel
after doing echo i get this graph image description
I see my error is that my plugin is not working over the same rostopic but how can i correct this?
my plugin is:
#include <boost/bind.hpp>
#include <gazebo/gazebo.hh>
#include "geometry_msgs/Twist.h"
#include <stdio.h>
static float velx=0.0,vely=0.0,velz=0.0,Vangx=0.0,Vangy=0.0, Vangz=0.0; // set as global
namespace gazebo
  class plugins : public ModelPlugin
      this->model = _parent;
      // simulation iteration.
      boost::bind(&plugins::OnUpdate, this, _1));
    // callback functions run every time data is published to the topic
    void ROSCallback_Vel(const geometry_msgs::Twist::ConstPtr& msg)
    velx=msg->linear.x;
    vely=msg->linear.y;
    velz=msg->linear.z;
    Vangx=msg->angular.x;
    Vangy=msg->angular.y;
    Vangz=msg->angular.z;
    public: void OnUpdate(const common::UpdateInfo & /*_info*/)
      // Apply a small linear velocity to the model.
      this->model->SetLinearVel(math::Vector3(velx, vely, velz));
       this->model->SetAngularVel(math::Vector3(Vangx, Vangy, Vangz));
    // Pointer to the model
  GZ_REGISTER_MODEL_PLUGIN(plugins)
Asked by wilmer on 2017-01-05 02:07:40 UTC
I believe the problem is that you are not creating a ROS node& ROS subscriber within your gazebo control plugin.
This tutorial should explain how to connect to ROS within a gazebo node. AKA create a ROS node and ROS subscriber object to connect to the ROS callback function you have defined ("ROSCallback_Vel")
http://gazebosim.org/tutorials?cat=guided_i&tut=guided_i6
Asked by Francis123 on 2017-01-25 17:28:53 UTC
