rotation two Gears in RViz and Gazebo
i have two gears in my urdf . i want rotate two gears in same time . U311 and U321 are gears .
my urdf :
<link
name="link_U31_1">
<origin
xyz="-8.87891218881443E-11 7.94085594724159E-07 -0.00670118881241989"
rpy="0 0 0" />
<mass
value="0.0791354618215319" />
<inertia
ixx="0"
ixy="0"
ixz="0"
iyy="0"
iyz="0"
izz="0" />
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
filename="file:///home/zakizadeh/catkin_ws3/src/wrist/meshes/link_U31_1.STL" />
<material
name="">
<color
rgba="0.792156862745098 0.819607843137255 0.933333333333333 1" />
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
<joint
name="joint_U31_1"
type="revolute">
<origin
xyz="0.0375000001895901 0 0.0547500000000001"
rpy="0 6.93889390390723E-16 0" />
<parent
link="link_U33_1" />
<child
link="link_U31_1" />
<axis
xyz="0 0 1" />
<limit effort="1.0" lower="-1.75" upper="1.75" velocity="3.14"/>
<link
name="link_U32_1">
<origin
xyz="-1.49046497366356E-10 -0.000127794819901189 1.88843510273706E-10"
rpy="0 0 0" />
<mass
value="0.019633991990533" />
<inertia
ixx="0"
ixy="0"
ixz="0"
iyy="0"
iyz="0"
izz="0" />
<visual>
<origin <link
name="link_U32_1">
<origin
rpy="0 0 0" />
<mass
<inertia
ixx="0"
ixy="0"
ixz="0"
iyy="0"
iyz="0"
izz="0" />
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
filename="file:///home/zakizadeh/catkin_ws3/src/wrist/meshes/link_U32_1.STL" />
<material
name="">
<color
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
<joint
name="joint_U32_1"
type="revolute">
<origin
xyz="-0.0075000004012061 0 0.0422500000000005"
rpy="1.5707963267949 0 1.5707963267949" />
<parent
<child
link="link_U32_1" />
<axis
xyz="0 1 0" />
xyz="0 0 0"
rpy="0 0 0" />
<mesh
<material
name="">
<color
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<mesh
<joint
name="joint_U32_1"
type="revolute">
<origin
<parent
<child
<axis
xyz="0 1 0" />
Asked by zakizadeh on 2017-01-06 07:31:01 UTC
How are you rotating the gears? Are the teeth meshed properly? Do you see contacts points between the gears? Your inertia values are incorrect, and should be fixed. Try reading through the gazebo tutorials to understand how to create simulation models.
Asked by nkoenig on 2017-01-06 09:30:12 UTC
i updated image in my question.i edited my urdf to create contacts points between the gears . can you wrirte A simple example for rotat two gears ??
Asked by zakizadeh on 2017-01-06 11:05:24 UTC
I can offer guidance, but I don't have the bandwidth to write code. There are numerous tutorials on both ROS and Gazebo. There are also many tools to help debug simulation (visualize inertia, collisions, contact points, etc), along with plotting tools, and logging. Please exhaust all of these resources. Include this in question all of the debugging and testing methods that you have tried. For example: your URDF has syntax errors that should be apparent when reading console output.
Asked by nkoenig on 2017-01-06 12:19:36 UTC
i send all robot files by email for you . i tried for 2 months ! but i cant solve problem . please help me.
Asked by zakizadeh on 2017-01-06 13:25:08 UTC
hi . I Tried so hard but I still have problems . I'm disappointed . can you help me please ! i need your help
Asked by zakizadeh on 2017-01-16 09:08:12 UTC
