Model sinks and bounces through floor like quicksand-trampoline combination
I'm new to Gazebo, so this may be a simple mistake. I've uploaded a single model created in Solidworks. At first, the model size was about 1000x larger than it was meant to be, probably because millimeters were interpreted as meters. However, the model would fall right through the ground plane immediately. After I changed the scale to make it 1000x smaller, and added collision, the model would then fall to the floor at a normal rate and began to sink at a slower rate, like quicksand. After some more adjustments, the model still sinks through the floor but then bounces back up, as if this "quicksand" has elastic properties. Note that the real time factor is running at around 0.03 most of the time. I honestly have no idea how to fix this. Here's my .world file:
<?xml version="1.0"?>
<uri>model://sun</uri>
<model name="my_mesh">
<pose>0 0 1 1.57 0 1.57</pose>
<static>false</static>
<link name="body">
<mesh>
<uri>file://BenpedalMesh1.dae</uri>
<scale>0.001 0.001 0.001</scale>
</mesh>
<mesh>
</mesh>
Asked by keylesslocknutbushing on 2017-01-08 23:42:21 UTC
Perhaps my computer just can't handle the simulation for collision of such a complex model? I suppose I'll have to create simpler collision elements for it instead of just using the mesh...?
Asked by keylesslocknutbushing on 2017-01-09 00:16:35 UTC
Simper collision elements are a good idea. And to help you debug the problem, you could start the simulation paused, turn on collision and contact visualization, and slowly step through simulation to inspect what's going on.
Asked by chapulina on 2017-01-09 11:34:57 UTC
I had the same problems, it was fixed by adding kd and kp tags.
Asked by Lyndwyrm on 2017-01-11 09:21:07 UTC
Can you explain what these kd and kp tags are?
Asked by aravindsrj on 2020-08-31 14:12:03 UTC
