Please what is the correct way to use AttachStaticModel function?
I am implementing a simple robot behavior where the robot represented as a box picks an object and drops it at a goal location. However, when the robot reaches the object location to pick it, it doesn't pick it.
A simplified version of the task has been attached mppickdrop.cc
All it does is to attach the m_litter to this->model and change the pose of the robot. This doesn't work, as the box just stays frozen at initialized pose. Please what am I getting wrong?
I am using gazebo 7
my robot model is a simple box.Robot sdf
object to pick (m_litter) is also a simple red box.object sdf
The world is world sdf
Many thanks in advance. The complete plugin source code is
Asked by elcymon on 2017-01-13 08:16:29 UTC
The API documentation says:
/// \brief Attach a static model to this model
/// This function takes as input a static Model, which is a Model that
/// has been marked as static (no physics simulation), and attaches it
/// to this Model with a given offset.
/// This function is useful when you want to simulate a grasp of a
/// static object, or move a static object around using a dynamic
/// model.
/// If you are in doubt, do not use this function.
/// \param[in] _model Pointer to the static model.
/// \param[in] _offset Offset, relative to this Model, to place _model.
Is the object that you're trying to pick up static?
Asked by nkoenig on 2017-01-13 09:58:07 UTC
Yes it is Static. I also added a code to set it from the source file if by any chance the model is not static. I used m_litter->SetStatic(true), and verified with m_litter->IsStatic().
I added a link to the full plugin code. I will try to attach an image of the source code also.
Asked by elcymon on 2017-01-13 10:08:13 UTC
Can you post your SDF file(s), and also let us know what version of gazebo you are using?
Asked by nkoenig on 2017-01-13 10:31:14 UTC
Yes. I am doing that now... I am using gazebo7
In the image uploaded, the object is set as not static, but I have tried it with
Asked by elcymon on 2017-01-13 10:51:09 UTC
Hi, am having the same issue - trying to attach a static model to a non static. I have the correct parameters - not sure what is wrong (there are nor errors thrown). In fact, if you use the function correctly with a NON static model, you will get the error "[Err] [Model.cc:1310] AttachStaticModel requires a static model" ....
Asked by Dougie DeRosa on 2019-08-20 16:00:36 UTC
Can you change0 to 1 in the m_litter sdf model?
Asked by nkoenig on 2017-01-13 11:28:09 UTC
Can you change
<static>0</static>
to<static>1</static>
in the m_litter sdf model?Asked by nkoenig on 2017-01-13 11:28:41 UTC
Can you change the static value from 0 to 1 in the m_litter sdf model?
Asked by nkoenig on 2017-01-13 11:29:13 UTC
I set static element to1 and it still didn't solve the problem.
gazebo -v returns version 7.4.0
Asked by elcymon on 2017-01-13 12:24:38 UTC
Your "OnUpdate" function is called every cycle of simulation. It would be better to call AttachStaticModel only once. This probably won't fix your problem.
Asked by nkoenig on 2017-01-13 16:36:02 UTC
