How to make move_group_python node move the pr2 in gazebo
How can i make the movegrouppythoninterfacetutorial.py to move the pr2 robot inside the gazebo. I have moved the pr2 inside the gazebo from this tutorial from a moveitplanningexecution.launch file and i've used this tutorial to move a pr2 robot inside the rviz. When try to put this node inside the moveitplanningexecution.launch file which contains the planning and execution component of moveit, the robot moves inside the rviz as the python code describes but the robot inside the gazebo is not moving. According to the movegroupinterfacepython tutorial after i uncomment the # group.go(wait=True) line shouldn't the pr2 inside gazebo also move sinnce all the controllers are active. How should i complete this task, i want to move a robot(right now pr2) from a action client/moveit python node, but i dont know right now how can i do it. The screen shot of the msgs after the line group.go() is:
My moveitplanning_execution.launch file:
<launch>
<include file="$(find pr2_moveit_config)/launch/move_group.launch">
<arg name="publish_monitored_planning_scene" value="true" />
<node name="move_group_python_interface_tutorial" pkg="pr2_moveit_tutorials" type="move_group_python_interface_tutorial.py" respawn="false" output="screen">
</node>
# The visualization component of MoveIt!
<include file="$(find pr2_moveit_config)/launch/moveit_rviz.launch"/>
</launch>
The move_group.launhc file has below lines:
<arg name="moveit_controller_manager" default="pr2_moveit_controller_manager/Pr2MoveItControllerManager" />
<param name="moveit_controller_manager" value="$(arg moveit_controller_manager)"/>
<arg name="controller_manager_name" default="pr2_controller_manager" />
<param name="controller_manager_name" value="$(arg controller_manager_name)" />
<arg name="use_controller_manager" default="true" />
<param name="use_controller_manager" value="$(arg use_controller_manager)" />
<rosparam file="$(find pr2_moveit_config)/config/pr2_execution_controllers.yaml"/>
<rosparam command="load" file="$(find pr2_moveit_config)config/pr2_execution_controllers.yaml"/>
and the pr2executioncontrollers.yaml file is:
controller_list:
- name: r_arm_controller
action_ns: follow_joint_trajectory
default: true
joints:
- r_shoulder_pan_joint
- r_shoulder_lift_joint
- r_upper_arm_roll_joint
- r_elbow_flex_joint
- r_forearm_roll_joint
- r_wrist_flex_joint
- r_wrist_roll_joint
- name: l_arm_controller
default: true
joints:
- l_shoulder_pan_joint
- l_shoulder_lift_joint
- l_upper_arm_roll_joint
- l_elbow_flex_joint
- l_forearm_roll_joint
- l_wrist_flex_joint
- l_wrist_roll_joint
- name: torso_controller
default: true
joints:
- torso_lift_joint
- name: r_gripper_controller
action_ns: gripper_action
default: true
joints:
- r_gripper_joint
- r_gripper_l_finger_joint
- r_gripper_r_finger_joint
- r_gripper_l_finger_tip_joint
- r_gripper_r_finger_tip_joint
- r_gripper_motor_screw_joint
- r_gripper_motor_slider_joint
- name: l_gripper_controller
default: true
joints:
- l_gripper_joint
- l_gripper_l_finger_joint
- l_gripper_r_finger_joint
- l_gripper_l_finger_tip_joint
- l_gripper_r_finger_tip_joint
- l_gripper_motor_screw_joint
- l_gripper_motor_slider_joint
- name: head_traj_controller
default: true
joints:
- head_tilt_joint
- head_pan_join
t I'm running
roslaunch pr2_moveit_config moveit_planning_execution.launch
I'm using ros indigo and gazebo 2.2 since i didn't found too much detail about how exactly is moveit working, i dont know exactly how to solve it.
Asked by hari1234 on 2017-01-16 02:49:36 UTC
