Modifying DefaultRobotHWSim for realistic wheel encoders
I am trying to add realistic wheel encoders to my Gazebo simulation. I use ros_control's DiffDriveController
, which sends velocity commands and reads the JointStates
topic published my Gazebo.
Using the DefaultRobotHWSim
interface, the perfect wheel positions and velocities are published by the plugin and used by the controller. I would like to modify these values (discretization, step miss, noise...) to simulate a real controller or to use them for odometry. I thus do not want to create a new topic, but instead to change the values of JointStates
From the documentation, I should create my own hardware interface that inherits from RobotHWSim
and pass it to gazebo_ros_control_plugin
through the robotSimType
field. This however does not allow me to pass arguments to the hardware interface (for example step size, step miss probability), since there seem to be no mechanism for gazebo_ros_control_plugin
to transmit values to RobotHWSim
, and this one can only read the .urdf
and not the .sdf
file (and the convention states that Gazebo-specific parameters should stay in the .sdf
Hence my question: should I write my own gazebo_ros_control_plugin
? This seems to totally break the modular approach of ROS and Gazebo, and am thus looking for a cleaner and more efficient way...
Asked by Skydes on 2017-01-17 23:16:53 UTC
Did you manage to implement DiffDriveController in Gazebo using RobotHWSim or DefaultRobotHWSim?
Asked by Toma Tacescu on 2017-12-06 02:05:16 UTC
