Gazebo crashes on model deletion
I am attempting to delete (and subsequently re-spawn, with a different 3D mesh) a static model in Gazebo. When I do, Gazebo is crashing consistently.
Here is an excerpt from the gazebo log:
gzserver: /usr/include/boost/smart_ptr/shared_ptr.hpp:653: typename boost::detail::sp_member_access<T>::type boost::shared_ptr<T>::operator->() const [with T = gazebo::physics::Inertial; typename boost::detail::sp_member_access<T>::type = gazebo::physics::Inertial*]: Assertion `px != 0' failed.
(truncated some plugin output here, which looks sane)
Aborted (core dumped)
================================================================================REQUIRED process [gazebo-2] has died!
process has died [pid 23768, exit code 134, cmd /opt/simulation/lib/gazebo_ros/gzserver -u -r -e ode /var/tmp/ros/temp.world __name:=gazebo __log:=/home/administrator/.ros/log/eb76bd24-e192-11e6-a6dd-005056b4a883/gazebo-2.log].
log file: /home/administrator/.ros/log/eb76bd24-e192-11e6-a6dd-005056b4a883/gazebo-2*.log
Initiating shutdown!
I'm calling the delete service from Python, as follows:
self._delete_env_cli = rospy.ServiceProxy('/gazebo/delete_model', DeleteModel)
try:
rospy.wait_for_service('/gazebo/delete_model')
resp = self._delete_env_cli(model_name='barrier')
except rospy.ServiceException as e:
rospy.logerr("Service did not process request: {}".format(e))
I see this behaviour with or without rospy.wait_for_service()
Gazebo 7.5.0, ROS Indigo. I'm also running GzWeb (head of gzweb_1.3.0) which is connected to this instance - not sure if that would impact anything.
Asked by JLiviero on 2017-01-23 13:16:27 UTC
Responding to @chapulina 's request here so I can attach the file. The full backtrace is attached. The model that caused this particular crash was a simple static cylinder primitive with a blink_visual plugin (but no custom plugins), though I have seen similar (not backtraced) crashes occur on a variety of models.
The attachment is just a text file, but has a .msg extension since this board only allows certain file types.
Asked by JLiviero on 2017-02-13 15:19:41 UTC
Could you get a backtrace using gdb? http://gazebosim.org/tutorials/?tut=ros_roslaunch#Exampleroslaunchcommand
Asked by chapulina on 2017-01-23 23:25:44 UTC
Wilco. Is there a method for getting debug symbols without building Gazebo from source? Just setting
debug=true
indicates:Reading symbols from gzserver...(no debugging symbols found)...done.
Asked by JLiviero on 2017-01-24 11:05:36 UTC
humm I think Gazebo needs to have been compiled in debug mode..
Asked by chapulina on 2017-01-25 11:20:49 UTC
Output has been posted below - let me know if you need anything else.
Asked by JLiviero on 2017-02-23 12:51:48 UTC
Hi @JLiviero, thanks for the backtrace. It looks like
physics::Link
is trying to access a nullphysics::Inertial
pointer. I was planning on trying to reproduce the issue using Gazebo without ROS when I have some time, so it's easier to investigate.Asked by chapulina on 2017-02-23 13:06:39 UTC
