GPU laser sensor reflects transparent glass material
Hello, I want to simulate a glass wall in Gazebo and see that the laser scanner can't detect it. In my model I tried to give different laser_retro and transparency settings. In Rviz I always see that the transparent wall reflects the laser scans. Can anybody shed some light on this ?
EDIT
I use Gazebo version 7.4 ROS Kinetic on Ubuntu 16.04
Below is the wall that is supposed not to reflect laser scans.
  <model name="glass1">
    <pose>7 2 1 0 0 0</pose>
      <collision name="visual">
         <laser_retro>0.5</laser_retro>
         <geometry><box><size>0.1 2 2</size></box></geometry>
      <visual name="visual1">
         <transparency>1</transparency>
              <script><name>Gazebo/RedTransparent</name></script>
Here is the laser plugin definition:
<gazebo reference="hokuyo_link">
<material>Gazebo/Red</material>
<sensor type="gpu_ray" name="hokuyo">
 <pose>0 0 0 0 0 0</pose>
 <visualize>false</visualize>
 <update_rate>40</update_rate>
  <ray>
    <scan>
      <horizontal>
         <samples>720</samples>
          <resolution>1</resolution>
      </horizontal>
    </scan>
    <range>
       <min>0.10</min> <max>30.0</max>
       <resolution>0.01</resolution>
    </range>
 </ray>
 <plugin name="gpu_laser" filename="libgazebo_ros_gpu_laser.so">
    <topicName>/scan</topicName>
    <frameName>hokuyo_link</frameName>
Asked by bustun on 2017-01-26 07:16:16 UTC
Can you post the version of gazebo you are using, the models you are simulating, the version of ROS, and any relevant code?
Asked by nkoenig on 2017-01-26 10:37:36 UTC
So basically the gpu laser will only detect a link's visual. One solution to your problem would be to simply delete the
in your sdf. But you would not be able to see the object in the simulation. Another possibility is to delete the
Element in your sdf and use the non gpu version of the sensor. This sensor will only detect a link's collision and you will be still able to see the object in the simulation. To do this you also need to change the sensor type:
<sensor type="ray" name="hokuyo">
and the plugin:
<plugin name="gazebo_ros_head_hokuyo_controller" filename="libgazebo_ros_laser.so">
Asked by wentz on 2018-09-06 09:46:38 UTC
