Need information on aerodynamic parameters of lift-drag plugin
Hi all,
I recently created a aircraft model and applied liftdrag plug into its control surfaces. I followed cessna aerodynamic parameters. But, I couldn't get the required flight. I think It would be useful if I fix these parameters according to my model. So, please give the source(or citation of research paper) from where the aerodynamic parameters such as cla,cda, etc are taken
<a0>0.4</a0>
<cla>4.752798721</cla>
<cda>0.6417112299</cda>
<cma>0</cma>
<alpha_stall>1.5</alpha_stall>
<cla_stall>-3.85</cla_stall>
<cda_stall>-0.9233984055</cda_stall>
<cma_stall>0</cma_stall>.
Asked by Ajith kumar on 2017-01-27 15:48:53 UTC
The parameters are described on this tutorial, hope that helps:
http://www.gazebosim.org/tutorials?tut=aerodynamics&cat=plugins
Asked by chapulina on 2017-10-02 10:02:43 UTC
Here I give a simple tutorial on how to get started with this plugin creating a simple example of movement with drag and lift in a robot with buoancy ( in water basicaly). This should serve as an extra of the previous answer. Here you have the video of this example:Video
I created a two link model, with a fin that will move and generate a drag that will move a sphere floating in water. You need to spawn the robot using the main_sphere_with_fin.launch. Inside it you have a world launch and a robot spawn. In this robot spawn among other things you spawn the urdf of the model where the plugin is set up. The urdf of floating_sphere_with_fin.urdf.
Inside it I set up the plugin in this fashion:
<gazebo>
        <plugin name="sphere_caudal_fin" filename="libLiftDragPlugin.so">
          <air_density>1000</air_density>
          <cla>0</cla>
        <cla_stall>0</cla_stall>
        <cda>1.2535816618911175</cda>
        <cda_stall>1.4326647564469914</cda_stall>
       <alpha_stall>0</alpha_stall>
       <a0>0</a0>
          <area>0.0334265458342</area>
          <upward>0 0 1.0</upward>
          <forward>-1.0 0 0</forward>
          <link_name>sphere_caudal_fin_link</link_name>
          <cp>0 0.19 0</cp>
As you can see here I only set the drag because I want it to move through the friction with the water, and no lift because the fin would generate one significantly. The Center of pressure ( cp) is places on the fin ( that is the distance from the center of the sphere to the tip of the fin where I want it to generate the force). Of course all this depends on your application.
Here I leave you the code of all the files used:
main.launch
ocean.world
sphere_with_fin_complete.launch
floating_sphere_with_fin.urdf.sdf
Hope this was usefull. If you state a more precise case scenario we could try to apply all this to your case in particular. This is just an example of how to use it in a basic way.
Edit:
This is an extra example for a more complex robot fish to move it through drag also: VIDEO PART 2
Asked by Duckfrost on 2017-11-13 13:00:40 UTC
