cant find inertial values from meshlab 1.3.3
I installed meshlab 1.3.3 as this tutorial says, but i cant findCompute Geometric Measures in the filters option, i also tried this answe for meshlab answer, but its not working, so i'm getting trouble using meshlab to compute the inertial values for the robot, can i still use meshlab to do this task somehow?
Asked by hari1234 on 2017-01-29 11:59:22 UTC
From your link seems there is a bug in the version you are using. Try the previous version 1.3.2, it is working fine.
Asked by mrslvgg on 2017-01-29 17:46:44 UTC
I am not being able to install 1.3.2 version manually and build it, how can i do that?
Asked by hari1234 on 2017-01-30 00:52:53 UTC
If you are working in windows here there is the link for download: http://download.cnet.com/MeshLab-64-bit/3000-6677_4-75755741.html
Asked by mrslvgg on 2017-01-30 03:57:08 UTC
i'm using ubuntu 14.04 and getting problem in building them.
Asked by hari1234 on 2017-01-30 09:45:37 UTC
