GazeboRosMagnetic sensor seems to be mounted backwards by default - How to change the orientation?
I am using GazeboRosMagnetic sensor plugin from hectorgazeboplugins and due to some reason it seems to be mounted backwards. Because after reading the heading value, my robot turns and goes backwards when I need it to be facing and moving forwards. I tried changing the offset parameter but that didn't seem to help, maybe I am not using the correct values?
Here's my code:
<plugin name="magnetometer" filename="libhector_gazebo_ros_magnetic.so">
<updateRate>20.0</updateRate>
<bodyname>base_footprint</bodyname>
<topicName>magnetometerStatus</topicName>
<referenceHeading>0.0</referenceHeading>
<declination>3.0333</declination>
<inclination>60.0</inclination>
<offset>0 0 0</offset>
<driftFrequency>0 0 0</driftFrequency>
<gaussianNoise>0 0 0</gaussianNoise>
Any help with this will be highly appreciated!
Many thanks
Asked by nerdyTurtle on 2017-02-03 11:02:22 UTC
