WideAngleCamera with FoV > 180 degrees
asked 2017-02-28 07:42:59 -0600
cvilas gravatar image
Is it possible to simulate this? I am trying to play around with settings in the SDF file - essentially I want to simulate a wide angle camera with 200 degrees FoV and 'equidistant' mapping function. From my tinkering with the camera SDF, it looks like the max FoV I can go to is 180 degrees. Even with 180 degrees, the image looks right with 'stereographic' mapping but not equidistant mapping
Hi, I'm having the same problem with the equidistant mapping. Have you solved it already?
christophburgmair gravatar imagechristophburgmair ( 2017-04-13 03:04:20 -0600 )edit
Ditto - the raw images using the sterographic projection (180d FOV) seem fine, but switching to equidistant (keeping everything else the same) appears with a cropped annular region which seems to having nothing much to do with the cutoff_angle parameter, which I've set to 90d. This would seem a strange bug to go unchecked?
adamziek gravatar imageadamziek ( 2018-02-07 09:16:27 -0600 )edit
