How can I dynamically get the coordinate of a model in gazebo?
I'm using Gazebo/ROS with TurtleBot. My robot needs to find the distance from itself to all the obstacles that exist in the environment while it is moving. I believe Laserscan has this information, but I am not sure how can I get the position of the models from Gazebo and reuse them in ROS with rospy. Can someone help me with some examples/tutorials?
Asked by Turtle on 2017-03-27 06:26:31 UTC
If you are running the gazebo_ros_laser plugin(or similar), it publishes a sensor_msgs/LaserScan.msg
to /scan
just like a real laser in ROS.
Check out the LaserScan Message page for details on the format of the messages published by the /scan
topic. One of the data elements in a LaserScan.msg
is an array of range values:
float32[] ranges
This has the range data you're probably looking for. It's up to you/your code to determine how to use it, what makes up an object, filter out noise, etc.
You can find the position of the TurtleBot by subscribing to the /tf
topic:
(About which see here and here, and of course, The ROS Wiki tf Tutorial)
If you don't know how to work with the rospy publish/subscribe framework, there are tutorials on ros.org: Writing Publishers and Subscribers in Python
HTH and please mark this as an answer if it helped you!
Asked by jetdillo on 2017-04-03 09:20:11 UTC
