Not Able to use laser scaner in Gazebo
I am new to Ubuntu,ROS and Gazebo. I have created a simple robot and trying to add laser scanner in it using this tutorial http://gazebosim.org/tutorials?tut=add_laser but when I use this code and try to drag robot on plan it start loading and don't give any error message and it also don't show database models "connecting to database models". What i am missing please help me. the code of robot model is this
<?xml version="1.0"?>
<sdf version="1.4">
<model name="my_robot">
<static>false</static>
<link name="chassis">
<pose>0 0 .1 0 0 0</pose>
<size>.4 .2 .1</size>
<collision name="caster_collision">
<pose>-0.15 0 -0.05 0 0 0</pose>
<sphere>
<radius>.05</radius>
</sphere>
<surface>
<friction>
<ode>
<mu>0</mu>
<mu2>0</mu2>
<slip1>1.0</slip1>
<slip2>1.0</slip2>
</ode>
</friction>
</surface>
<visual name="caster_visual">
<sphere>
</sphere>
<link name="left_wheel">
<pose>0.1 0.13 0.1 0 1.5707 1.5707</pose>
<cylinder>
<radius>.1</radius>
<length>.05</length>
</cylinder>
<cylinder>
<radius>.1</radius>
</cylinder>
<link name="right_wheel">
<pose>0.1 -0.13 0.1 0 1.5707 1.5707</pose>
<cylinder>
<radius>.1</radius>
</cylinder>
<cylinder>
<radius>.1</radius>
</cylinder>
<joint type="revolute" name="left_wheel_hinge">
<pose>0 0 -0.03 0 0 0</pose>
<child>left_wheel</child>
<parent>chassis</parent>
<axis>
<xyz>0 1 0</xyz>
</axis>
<joint type="revolute" name="right_wheel_hinge">
<pose>0 0 0.03 0 0 0</pose>
<child>right_wheel</child>
<axis>
<xyz>0 1 0</xyz>
</axis>
<uri>model://hokuyo</uri>
<pose>0.2 0 0.2 0 0 0</pose>
<joint name="hokuyo_joint" type="revolute">
<child>hokuyo::link`</child>
<axis>
<xyz>0 0 1</xyz>
<limit>
<upper>0</upper>
<lower>0</lower>
</limit>
</axis>
Asked by Sonia Nazish on 2017-04-12 09:48:01 UTC
Are you running the Gazebo first time , by any chance? First time it gets started it needs to download some models from its central server. Perhaps it is the connection problem of some kind.
Asked by eugene-katsevman on 2017-04-12 10:58:14 UTC
there is an extra ` in the hokuyo_joint link name, not sure if that's the problem
Asked by iche033 on 2017-04-13 12:04:42 UTC
there is an extra ` in the hokuyo_joint child link name, not sure if that's the problem
Asked by iche033 on 2017-04-13 12:05:28 UTC
