Camera issue when using Virtual Machine
I am using ROS Kinetic, Gazebo 7.0 on a VirtualBox VM (I had the same issues with VMWare too) with Ubuntu 16.04
I believe that this is an issue with the fact that I am using a VM and does not occur when used directly on an Ubuntu machine.. unfortunately, I need to use the VM. I have seen a number of posts where people have had issues when using VMs, however, I have been unsuccessful in fixing my own issue.
I have a .world file which I use to launch a robot model which I have, this model includes a camera. I don’t have any issues with my model, until I try to access data from the camera. For example, when I try to rostopic echo or image_view.
It doesn’t cause a crash, but in the terminal that I use to launch the .world file, the following error appears:
StartingGazeboRosSkidSteerDrive plugin (ns = )! gzserver; /build/ogre-1.9-mqY1wq/ogre-1.9-1.9.0+dfsg1/OgreMain/src/OgreRenderSystem.cpp:546: virtual void Ogre::RenderSystem::setDepthBufferFor(Ogre::RenderTarget*): Assertion `bAttached && A new DepthBuffer for a RenderTarget was created, but after creation" "it says it's incompatible with that RT"' failed.
I read a suggestion that said to lower the version of Ogre used (using the command: export SVGA_VGPU10=0), however this does not work, I get the same error.
Another suggestion was to uncheck the “Accelerate 3D graphics” option, though this also did not have any effect.
I was pointed towards a tutorial aimed at (I believe) a related problem, however, after following this I get a different error. I followed the tutorial posted here adjusting for my version of ROS and the most recent version of Gazebo:
Tutorial here: Fixing the gazebo 2.2 Virtual Machine Depth Ordering Bug
I can run Gazebo, but when I try to run my .world file using the command “rosrun gazebo_ros gazebo –file [filename].world” I get the following error:
gzserver: error while loading shared libraries: libsdformat.so.5: cannot open shared object file: No such file or directory
I am still relatively new to ROS and Gazebo, so I apologise if I have missed something obvious. Any help would be appreciated, thanks.
Asked by LukeT on 2017-04-28 06:36:20 UTC
are you using a normal camera, wide angle camera, or a depth camera?
Asked by iche033 on 2017-05-01 11:46:15 UTC
Just a normal camera
Asked by LukeT on 2017-05-03 08:07:07 UTC
Hi Luke, I have arrived at the same problem. Did you find a solution in the end?
Asked by MarcusFutterlieb on 2018-11-13 04:12:17 UTC
