(Solved) How can i solved: Deprecated syntax, please prepend 'hardware_interface/' ?
asked 2017-05-21 07:54:47 -0600
Hello everyone.
I am trying to display my model robot in gazebo and get this warning:
Deprecated syntax, please prepend 'hardware_interface/' to 'PositionJointInterface' within the <hardwareinterface> tag in joint 'joint_base'.
I know it's not important but I want to solve it.
This is my code in the xacro file of the transmission block:
<xacro:macro name="transmission_block" params="joint_name">
  <transmission name="tran1">
    <joint name="${joint_name}">
      <hardwareInterface>PositionJointInterface</hardwareInterface>
    <actuator name="motor1">
    </actuator>
  </transmission>
</xacro:macro>
Hi, I have the same warning, but when I append "hardware_interfase/" I receive this:
No matching hardware interface found for 'hardware_interfase/EffortJointInterface' while loading interfaces for pitch_joint
lejan gravatar imagelejan ( 2021-05-06 09:25:13 -0600 )edit
answered 2017-05-21 14:48:56 -0600
hamzamerzic gravatar image
updated 2017-05-21 14:49:23 -0600
As you said, it is just a warning and doesn't break anything. To stop the message, simply follow the warning message to get:
<hardwareInterface>hardware_interface/PositionJointInterface</hardwareInterface>
thaaank you!!
Daniel Tobon gravatar imageDaniel Tobon ( 2017-05-23 19:43:35 -0600 )edit
I have a related issue. My transmission is set up as
    <joint name="waist">
      <hardwareinterface>EffortJointInterface</hardwareinterface>
      <mechanicalreduction>1</mechanicalreduction>
    </actuator>
  </transmission>
Mav14 gravatar imageMav14 ( 2017-11-08 16:48:36 -0600 )edit
And this is the error I get Could not find resource 'waist' in 'hardware_interface::EffortJointInterface'.. I can't figure out what's causing that despite looking everywhere.
Mav14 gravatar imageMav14 ( 2017-11-08 16:49:36 -0600 )edit
2 followers
Asked: 2017-05-21 07:54:47 -0600
Seen: 9,235 times
Last updated: May 23 '17
