Gazebo 7 launching error
Almost every time I run gazebo I get this error.
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::lock_error> >'
what(): boost: mutex lock failed in pthread_mutex_lock: Invalid argument
Aborted (core dumped)
I have to run it multiple times to get it working. To note that I run it with an empty world, and I spawn a robot in it.
Code for reference:
<launch>
<!-- these are the arguments you can pass this launch file, for example paused:=true -->
<arg name="use_sim_time" default="true"/>
<arg name="headless" default="false"/>
<arg name="debug" default="false"/>
<arg name="model" default="$(find my_package)/urdf/atlas.xacro"/>
<!-- We resume the logic in empty_world.launch, changing only the name of the world to be launched -->
<arg name="debug" value="$(arg debug)" />
<arg name="gui" value="$(arg gui)" />
<arg name="paused" value="$(arg paused)"/>
<arg name="use_sim_time" value="$(arg use_sim_time)"/>
<arg name="headless" value="$(arg headless)"/>
<param name="robot_description" command="$(find xacro)/xacro $(arg model)" />
<!-- push robot_description to factory and spawn robot in gazebo -->
<node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model"
args="-z 1.0 -unpause -urdf -model robot -param robot_description" respawn="false" output="screen" />
<node pkg="robot_state_publisher" type="robot_state_publisher" name="robot_state_publisher">
<param name="publish_frequency" type="double" value="30.0" />
</node>
</launch>
UPDATE 1 The problem appears when I launch with control parameters. I am using a diff controller to control 2 wheels just for testing and a prism joint that I control also.
UPDATE 2 When spawning without control also. Regards
Asked by SorinV on 2017-05-22 09:40:40 UTC
So when you launch the empty world it doesn't crash, but it crashes after the robot is spawned?
Asked by chapulina on 2017-05-22 09:53:59 UTC
Thank you for the reply. The error does not have a measurable recurrency. But yes, sometimes it crashes like so at startup. For roslaunch gazebo_ros empty_world.launch it works fine. But stil get libGL error: failed to create drawable libGL error: failed to create drawable but this may just be a driver problem. To respond to your question, It crashes while launching Gazebo, waiting indefinitely for the mutex.
Asked by SorinV on 2017-05-23 04:06:20 UTC
