Gazebo 7.0.0 crash on heightmap insertion
asked 2017-05-28 21:56:02 -0600
WarwickWagon gravatar image
In Gazebo 7.0.0 if I try to insert an model with a heightmap Gazebo either hangs or closes with a crash. In the following example, I attempt to insert the Appolo15 landing model
Either I'll get
$ gazebo --verbose
Gazebo multi-robot simulator, version 7.0.0
Copyright (C) 2012-2016 Open Source Robotics Foundation.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 132.207.24.8
[Wrn] [Event.cc:87] Warning: Deleteing a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
[Err] [Visual.cc:2726] No mesh specified
Or I might get this this message too
gzclient: /usr/include/boost/smart_ptr/shared_ptr.hpp:648: typename boost::detail::sp_member_access<T>::type boost::shared_ptr<T>::operator->() const [with T = gazebo::msgs::Response; typename boost::detail::sp_member_access<T>::type = gazebo::msgs::Response*]: Assertion `px != 0' failed.
Any ideas? Wondering if the easy fix is to uninstall the Gazebo version that ships with ROS and install the latest one.
I have this same exact issue happen on 7.0.0 but it only happens for heightmaps which are 2049 x 2049 or larger. For maps of size 1025 x 2015 and smaller it loads properly.
ChrisThrasher gravatar imageChrisThrasher ( 2017-08-01 15:12:02 -0600 )edit
answered 2017-05-30 10:57:31 -0600
chapulina gravatar image
updated 2019-04-06 15:06:25 -0600
yah130s gravatar image
Actually it might not even be necessary to go that far, I was able to insert heightmaps using Gazebo 7.7. All you need are OSRF keys, and then sudo apt upgrade.
answered 2017-05-28 23:51:26 -0600
An easy but probably not optimal solution is to install Gazebo 8. It's not the version that ships with ROS Kinetic, but at least it gets things working.
2 followers
Asked: 2017-05-28 21:56:02 -0600
Seen: 784 times
Last updated: May 28 '17
