publish /gps/fix topic by libhector_gazebo_ros_gps
I want to publish the robot's pose by gps. i used the hector_gazebo_plugins. i use plugin tag in the urdf model:
<robot>
<gazebo>
<plugin name="hector_gps" filename="libhector_gazebo_ros_gps.so">
<robotNamespace>/sos1</robotNamespace>
<updateRate>50.0</updateRate>
<bodyName>base_link</bodyName>
<frameId>map</frameId>
<topicName>gps/fix</topicName>
<velocityTopicName>gps/fix_velocity</velocityTopicName>
</robot>
the topics are publishing but the latitude and longitude are fixed although the robot is moving.
and here is the frames of the robot:
my question is, for publishing the valid latitude and longitude, my plugin tag is enough? and if yes, so whats the problem?
some of published data in /sos1/gps/fix topic:
header: seq: 1468 stamp: secs: 5603 nsecs: 700000000 frame_id: map status: status: 0 service: 0 latitude: 49.8999358331 longitude: 8.90010757962 altitude: 0.0500032459217 position_covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0] position_covariance_type: 2
header: seq: 1469 stamp: secs: 5603 nsecs: 720000000 frame_id: map status: status: 0 service: 0 latitude: 49.8999358331 longitude: 8.90010757961 altitude: 0.050003245824 position_covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0] position_covariance_type: 2
