how to use gazebo_ros_f3d contact sensor
Goal: I would like to add a contact sensor gazebo plugin to robot in Gazebo, which can connect to ROS (indigo + gazebo7+ubuntu14). Specifically, adding gazeborosf3d contact sensor to grasping_frame link.
I learn from Tutorial: Using Gazebo plugins with ROS
I add the below script to source code of MODEL.xacro, in the meanwhile reference to the source code of gazeborosf3d for contact message and Camera section
<!-- modify the script of Camera section to corresponding contact plugin according to gazebo_ros_f3d.cpp API--->
<gazebo reference="grasping_frame">
<sensor type="contact" name="my_contact">
<update_rate>30.0</update_rate>
<contact>
<collision>grasping_frame_collision</collision>
</contact>
<plugin name="contact_sensor_controller" filename="libgazebo_ros_f3d.so">
<robotNamespace>/seven_dof_arm</robotNamespace>
<bodyName>grasping_frame</bodyName>
<topicName>grasping_frame_contact_fb</topicName>
<frameName>grasping_frame</frameName>
Then I
roslaunch seven_dof_arm_gazebo seven_dof_arm_world.launch
gazebo crash:
[ INFO] [1496675172.098873708, 0.022000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1496675172.124006178, 0.047000000]: Physics dynamic reconfigure ready.
[INFO] [WallTime: 1496675172.168461] [0.089000] Calling service /gazebo/spawn_urdf_model
Service call failed: transport error completing service call: unable to receive data from sender, check sender's logs for details
[gazebo-2] process has died [pid 8635, exit code 139, cmd /opt/ros/indigo/lib/gazebo_ros/gzserver -e ode /home/shawn/catkin_ws/src/gazebo_ros_demos/rrbot_gazebo/worlds/rrbot.world __name:=gazebo __log:=/home/shawn/.ros/log/827c11a8-4a00-11e7-bf24-e4a4716f540f/gazebo-2.log].
log file: /home/shawn/.ros/log/827c11a8-4a00-11e7-bf24-e4a4716f540f/gazebo-2*.log
[gazebo_gui-3] process has died [pid 8659, exit code 255, cmd /opt/ros/indigo/lib/gazebo_ros/gzclient __name:=gazebo_gui __log:=/home/shawn/.ros/log/827c11a8-4a00-11e7-bf24-e4a4716f540f/gazebo_gui-3.log].
log file: /home/shawn/.ros/log/827c11a8-4a00-11e7-bf24-e4a4716f540f/gazebo_gui-3*.log
[urdf_spawner-4] process has finished cleanly
log file: /home/shawn/.ros/log/827c11a8-4a00-11e7-bf24-e4a4716f540f/urdf_spawner-4*.log
I open spawner-4*.log file to check:
[rosout][INFO] 2017-06-05 23:02:20,171: Loading model xml from ros parameter
14 [rosout][INFO] 2017-06-05 23:02:20,177: Waiting for service /gazebo/ spawn_urdf_model
15 [rospy.internal][INFO] 2017-06-05 23:02:20,373: topic[/rosout] adding connection to [/rosout], count 0
16 [rospy.internal][INFO] 2017-06-05 23:02:20,675: topic[/clock] adding connection to [http://evashawn:35881/], count 0
17 [rosout][INFO] 2017-06-05 23:02:20,783: Calling service /gazebo/ spawn_urdf_model
18 [rospy.core][INFO] 2017-06-05 23:02:21,011: signal_shutdown [atexit]
19 [rospy.internal][WARNING] 2017-06-05 23:02:21,012: Unknown error initiating TCP/IP socket to evashawn:33521
(http://evashawn:35881/): Traceback (most recent call last):
20 File "/opt/ros/indigo/lib/python2.7/dist-packages/rospy/impl/tcpros_base. py", line 555, in connect
21 self.socket.connect((dest_addr, dest_port))
22 File "/usr/lib/python2.7/socket.py", line 224, in meth
23 return getattr(self._sock,name)(*args)
24 error: [Errno 111] Connection refused
25
26 [rospy.internal][INFO] 2017-06-05 23:02:21,012: topic[/clock] removing connection to http://evashawn:35881/
27 [rospy.internal][INFO] 2017-06-05 23:02:21,013: topic[/rosout] removing connection to /rosout
28 [rospy.impl.masterslave][INFO] 2017-06-05 23:02:21,013: atexit
What's going on? Thanks!
Asked by shawnysh on 2017-06-05 10:24:35 UTC
I look through this code of PR2 and found the solution.
gazebo_ros_f3d plugin must be put directly in gazebo tag rather than under sensor tag. The link which plugin is attached to is specified by child element of plugin, which is bodyName
Asked by shawnysh on 2017-06-11 19:27:42 UTC
