Error while compiling Gazebo Ros plugin
Hello, I am using Ubuntu 14.04 and ROS Indigo with Gazebo 2.2.6. I am trying to compile a gazebo ros plugin. Here is the code.
armbot_plugin.hpp:
#ifndef _ARMBOT_PLUGIN_HH_
#define _ARMBOT_PLUGIN_HH_
#include <iostream>
#include <ros/ros.h>
#include <geometry_msgs/Twist.h>
namespace gazebo{
class GAZEBO_VISIBLE RobotDriver : public WorldPlugin
private:
//! The node handle we'll be using
ros::NodeHandle nh_;
//! We will be publishing to the "/base_controller/command" topic to issue commands
ros::Publisher cmd_vel_pub_;
public:
//! ROS node initialization
RobotDriver(ros::NodeHandle &nh) : WorldPlugin()
nh_ = nh;
//set up the publisher for the cmd_vel topic
cmd_vel_pub_ = nh_.advertise<geometry_msgs::Twist>("/base_controller/command", 1);
//! Loop forever while sending drive commands based on keyboard input
bool driveKeyboard()
std::cout << "Type the angle in rads (0,0.5) and press enter "
"Press '.' to exit.\n";
//we will be sending commands of type "twist"
geometry_msgs::Twist base_cmd;
int cmd;
while(nh_.ok()){
std::cin >> cmd;
if(cmd>0.5 || cmd<0 && cmd!='.')
std::cout << "unknown command:" << cmd << "\n";
continue;
//base_cmd.linear.x = base_cmd.linear.y = base_cmd.angular.z = 0;
//turn left (yaw) and drive forward at the same time
//quit
else if(cmd=='.'){
break;
else {
base_cmd.angular.y = cmd;
std::cout << "Type the twist in rads (-0.5,0.5) and press enter "
cmd=0;
std::cin >> cmd;
if(cmd>0.5 || cmd<-0.5 && cmd!='.')
continue;
//quit
else if(cmd=='.'){
break;
else {
base_cmd.angular.z = cmd;
//publish the assembled command
cmd_vel_pub_.publish(base_cmd);
return true;
#endif
armbot_plugin.cpp:
#include <iostream>
#include "armbot_plugin.hpp"
using namespace gazebo;
GZ_REGISTER_WORLD_PLUGIN(RobotDriver)
int main(int argc, char** argv)
//init the ROS node
ros::init(argc, argv, "robot_driver");
ros::NodeHandle nh;
RobotDriver driver(nh);
driver.driveKeyboard();
and I get the following errors
In file included from /home/sofia/catkin_ws/src/armbot_plugin/src/armbot_plugin.cpp:4:0:
/home/sofia/catkin_ws/src/armbot_plugin/src/armbot_plugin.hpp:13:34: error: expected initializer before ‘:’ token
/home/sofia/catkin_ws/src/armbot_plugin/src/armbot_plugin.cpp:18:1: error: expected ‘}’ at end of input
make[2]: *** [armbot_plugin/CMakeFiles/armbot_plugin.dir/src/armbot_plugin.cpp.o] Error 1
make[1]: *** [armbot_plugin/CMakeFiles/armbot_plugin.dir/all] Error 2
make: *** [all] Error 2
If I remove the "GAZEBO_VISIBLE" Macro I get this error:
In file included from /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.hpp:8:0, from /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.cpp:4: /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.cpp: In function ‘gazebo::WorldPlugin* RegisterPlugin()’: /usr/include/gazebo-2.2/gazebo/common/Plugin.hh:408:26: error: cannot allocate an object of abstract type ‘gazebo::RobotDriver’ return new classname();\ ^ /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.cpp:8:1: note: in expansion of macro ‘GZREGISTERWORLDPLUGIN’ GZREGISTERWORLDPLUGIN(RobotDriver) ^ In file included from /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.cpp:4:0: /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.hpp:13:7: note: because the following virtual functions are pure within ‘gazebo::RobotDriver’: class RobotDriver : public WorldPlugin ^ In file included from /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.hpp:8:0, from /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.cpp:4: /usr/include/gazebo-2.2/gazebo/common/Plugin.hh:268:26: note: virtual void gazebo::WorldPlugin::Load(gazebo::physics::WorldPtr, sdf::ElementPtr) public: virtual void Load(physics::WorldPtr world, ^ /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.cpp: In function ‘int main(int, char*)’: /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.cpp:16:15: error: cannot declare variable ‘driver’ to be of abstract type ‘gazebo::RobotDriver’ RobotDriver driver(nh); ^ In file included from /home/sofia/catkinws/src/armbotplugin/src/armbotplugin.cpp:4:0: /home/sofia/catkinws/src/armbotplugin/src/armbot_plugin.hpp:13:7: note: since type ‘gazebo::RobotDriver’ has pure virtual functions class RobotDriver : public WorldPlugin ^ make[2]: ** [armbotplugin/CMakeFiles/armbotplugin.dir/src/armbotplugin.cpp.o] Error 1 make[1]: *** [armbotplugin/CMakeFiles/armbot_plugin.dir/all] Error 2 make: *** [all] Error 2
Asked by sofia.gr on 2017-06-12 04:05:46 UTC
