model set to be immovable still move after collide with other model
Goal:
I want to set base_link of robot arm fixed to the ground_plane of the world. When moving robot arm collides with surface of wall, because baselink is fixed to ground, arm has to stop moving(or rather, try to moving to penetrate but doesn't work) instead of the baselink moving away.
Background:
I have learnt how to fix box model onto the world from this question, by adding static tag of gazebo tag under robot tag in xacro, reference to using urdf in gazebo
However, it doesn't work for the robot arm, though I have done the same trick for robot arm's xacro.
<material>Gazebo/White</material>
<!--test: set base_link fixed to world
however, it doesn't work! -->
Or try this one:
<!--test: set seven_dof_arm immovable? However it doesn't work!!! -->
<gazebo>
When moving robot arm hits the surface of box, the base_link of robot arm is forced to move away.
Original pose of robot arm
Robot arm yields to the inter-force and base_link moves away
Asked by shawnysh on 2017-06-13 06:12:13 UTC
