Overlay gui is not invisible
Hi everybody,
I have a gui plugin which is so similar to one in gui overlay tutorial. the issue is when I use that plugin the widgets which is a button is not visible. Before I was over gazebo 7 and it was invisible but if I click on its location it works. I searched and I found there was a bug there and it is solved on gazebo 8. Now I am on gazebo 8 but the widget is not visible nor it doesn't do anything if I click on its location.
EDIT: I switched again to gazebo 7 and I noticed the gui plugin is not loaded in gazebo8. I print something in constructor, I can see it in gazebo 7 but not in gazebo8. everything is same and the only difference is gazebo version.
Anybody knows how can I solve that?
Thanks in advance!
Asked by Vahid on 2017-06-21 12:02:57 UTC
I believe this was a known bug which was fixed on the latest release of Gazebo 8. Could you check your exact version? And try sudo apt upgrade?
Asked by chapulina on 2017-06-21 12:40:56 UTC
yes, you are right. I did that. my current version is 8.1 which is the last version.
Asked by Vahid on 2017-06-21 13:38:54 UTC
