Is there a way to run Gazebo on an AWS server?
I am running an AWS EC2 (Ubuntu 14.04) instance and have tunneled using VNC so I have a GUI of the desktop. However, when I enter "gazebo" in the command line after installing Gazebo 7, I receive the following error.
X Error of failed request: BadMatch (invalid parameter attributes) Major opcode of failed request: 148 (GLX) Major opcode of failed request: 5 (XGLXMakeCurrent) Serial number of failed request: 19 Current serial number in output stream: 19 Major opcode of failed request: _148(GLX) Minor opcode of failed request: 5 (XGLXMakeCurrent) ...
Any help would be appreciated!
Asked by levya on 2017-06-23 17:12:53 UTC
Usually there's no X server by default on an AWS EC2 machine. You may be able to run gzserver but not gzclient or gazebo. In order to run gazebo or gzclient you need to find a tutorial about how to configure an X server on an Ubuntu server distribution. When working, you could take a snapshot of your system (AMI on the Amazon lingo) and you should be able to reproduce the installation easily.
Asked by Carlos Agüero on 2017-06-26 14:17:16 UTC
Just a note, an X server is also needed by gzserver for rendering the output of camera sensors.
Asked by sloretz on 2017-06-27 13:02:34 UTC
True, a laser sensor might need a GPU too, so it really depends on your use case.
Asked by Carlos Agüero on 2017-06-27 13:17:42 UTC
Thanks for the replies. I'm having trouble finding tutorials that could help me install an X server on AWS. Please let me know if you come across any helpful resources. Thanks!
Asked by levya on 2017-06-27 13:20:21 UTC
@levya, you could try running Xvfb (http://elementalselenium.com/tips/38-headless) on such a headless machine.
Asked by JLiviero on 2017-06-27 14:31:14 UTC
