Problem running a modelplugin
Hello, I am running this plugin: https://pastebin.com/HUUJFMnU but my joints are not moving. I tried to put a ROS_INFO message into each function to see if they are printed. Load function message is printed once, Onupdate function message is printed endlessly and RosCallback function message never gets printed. Why is this happening? What should I change?
#include <boost/bind.hpp>
#include <gazebo.hh>
#include <physics/physics.hh>
#include <common/common.hh>
#include <stdio.h>
#include "ros/ros.h"
#include "std_msgs/Float64.h"
#include "geometry_msgs/Twist.h"
namespace gazebo
  class ROSModelPlugin : public ModelPlugin
    public: ROSModelPlugin()
      // Start up ROS
      std::string name = "gazebo_p3at";
      int argc = 0;
      ros::init(argc, NULL, name);
    public: ~ROSModelPlugin()
      delete this->node;
      this->model = _parent;
      // ROS Nodehandle
      this->node = new ros::NodeHandle("~");
      // ROS Subscriber
      this->sub = this->node->subscribe<geometry_msgs::Twist>("cmd_vel", 10, &ROSModelPlugin::ROSCallback, this );
      // simulation iteration.
      this->updateConnection = event::Events::ConnectWorldUpdateStart(
          boost::bind(&ROSModelPlugin::OnUpdate, this));
    public: void OnUpdate()
      ros::spinOnce();
    void ROSCallback(const boost::shared_ptr<geometry_msgs::Twist const>& cmd_vel)
      physics::Joint_V joints = this->model->GetJoints();
      float maxForce = 3.0;
      joints[0]->SetMaxForce(0, maxForce);
      joints[1]->SetMaxForce(0, maxForce);
      joints[2]->SetMaxForce(0, maxForce);
      joints[3]->SetMaxForce(0, maxForce);
      float wheelRadius = 0.110; // (Meters)
      float wheelBase   = 0.250; // Distance between opposite wheels (Meters)
      float RotVel_lin = cmd_vel->linear.x / wheelRadius;
      float RotVel_rot = cmd_vel->angular.z * (wheelBase / wheelRadius);
      joints[0]->SetVelocity(0, RotVel_lin - RotVel_rot);
      joints[1]->SetVelocity(0, RotVel_lin - RotVel_rot);
      joints[2]->SetVelocity(0, RotVel_lin + RotVel_rot);
      joints[3]->SetVelocity(0, RotVel_lin + RotVel_rot);
      ROS_INFO("cmd_vel: [%f, %f]"
              , cmd_vel->linear.x
              , cmd_vel->angular.z );
    // Pointer to the model
    // ROS Nodehandle
    private: ros::NodeHandle* node;
    // ROS Subscriber
    ros::Subscriber sub;
  GZ_REGISTER_MODEL_PLUGIN(ROSModelPlugin)
Asked by sofia.gr on 2017-07-05 14:59:12 UTC
Hope you don't mind, I added the text of the plugin to the question body in case the pastebin link breaks in the future.
Asked by sloretz on 2017-07-05 15:04:02 UTC
