Modified Camera Orbit view behaviour after exiting follow mode
I've been playing with the camera track_visual element. I've setup to position the camera at a fixed position when follow is toggled:
<track_visual>
<static>1</static>
<use_model_frame>1</use_model_frame>
<xyz>8 0 5</xyz>
<inherit_yaw>1</inherit_yaw>
</track_visual>
However, once the follow mode exited, the camera orbit mode (middle mouse button) behaviour changes. "Normally" the middle mouse button let you ajust the camera yaw and pitch angle but once I enter and exit follow mode orbit also affects the camera roll angle.
Asked by AlexandreB on 2017-07-05 15:46:17 UTC
