Error while running simple gazebo plugin
I am working with ubuntu 14.04, indigo and gazebo 2.2.6. I am trying to run the same code as in this question http://answers.gazebosim.org/question/2105/basic-joint-control-question/ but I get the following error:
gzserver: /usr/include/boost/smartptr/sharedptr.hpp:653: typename boost::detail::spmemberaccess
::type boost::sharedptr ::operator->() const [with T = gazebo::physics::Joint; typename boost::detail::sp member_access::type = gazebo::physics::Joint*]: Assertion `px != 0' failed.
My code is here:
#include <boost/bind.hpp>
#include <gazebo/gazebo.hh>
#include <stdio.h>
namespace gazebo
class ArmovePlugin : public ModelPlugin
this->model = _parent;
// Initialize the JointController with the model pointer
this->j_controller = new physics::JointController(_parent);
// simulation iteration.
boost::bind(&ArmovePlugin::OnUpdate, this, _1));
public: void OnUpdate(const common::UpdateInfo & /*_info*/)
double angle(3.0);
j_controller->SetJointPosition(this->model->GetJoint("joint1"), angle);
private: physics::JointController * j_controller;
GZ_REGISTER_MODEL_PLUGIN(ArmovePlugin)
urdf:
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro" name="armbot">
<xacro:property name="velocity1" value="100" />
<xacro:property name="effort1" value="1000" />
<xacro:property name="lowerlimit" value="-1.57079" />
<xacro:property name="upperlimit" value="1.57079" />
<link name="world"/>
<joint name="joint0" type="fixed">
<parent link="world"/>
<child link="part1"/>
<link name="part1">
<visual>
<cylinder length="0.9" radius="0.05"/>
<origin rpy="0 1.57079 0" xyz="0 0 0"/>
<material name="blackmetal">
<color rgba="0.1 0.1 0.1 0.7"/>
<collision>
<mass value="9"/>
<inertia ixx="0.6" ixy="0.0" ixz="0.0" iyy="0.6" iyz="0.0" izz="3.64"/>
<link name="part2">
<visual>
<cylinder length="0.6" radius="0.05"/>
<origin rpy="0 0 0" xyz="0.45 0 0.3"/>
<material name="blackmetal2">
<collision>
<origin rpy="0 0 0" xyz="0 0 0"/>
<mass value="6"/>
<inertia ixx="0.18" ixy="0.0" ixz="0.0" iyy="0.18" iyz="0.0" izz="1.08"/>
<joint name="joint1" type="revolute">
<parent link="part1"/>
<child link="part2"/>
<origin xyz="0.45 0 0"/>
<axis rpy="0 0 0" xyz="0 1 0" />
<calibration rising="0.0"/>
<dynamics damping="0.0" friction="0.0"/>
<limit effort="${effort1}" lower="${lowerlimit}" upper="${upperlimit}" velocity="${velocity1}"/>
<gazebo>
<plugin name="armbot_plugin" filename="libarmbot_plugin.so"> </plugin>
</robot>
Asked by sofia.gr on 2017-07-13 11:55:57 UTC
The first recommendation would be to upgrade to Gazebo 7, since Gazebo 2 is no longer supported.
Asked by chapulina on 2017-07-13 12:28:00 UTC
I tried Gazebo 7, and I still get the same error.
Asked by sofia.gr on 2017-07-13 14:44:34 UTC
I added the code. Does the fact that I have a urdf file cause any problem? Should I declare the plugin as world plugin? I was able to run model plugins that use PID to move the joint, but I want it to move according to the angle
Asked by sofia.gr on 2017-07-14 12:03:06 UTC
