XACRO: Acutator use in gazebo turn robot to a strange performance
I know where I am wrong.
I put the wrong hardware interface.
Do not use PositionJointInterface and the problem was solved.
The question will be closed.
Thanks. --------Original Question-----------------------------
I am not sure whether I can state clearly. I will try my best.
I used ROS & Gazebo to do my Robot Simulation
I follow the Tutorial of URDF to the gazebo part.
However, I found if I add the following part
  <transmission name="head_swivel_trans">
    <actuator name="$body_to_head_motor">
      <mechanicalReduction>100</mechanicalReduction>
    </actuator>
    <joint name="body_to_head">
      <hardwareInterface>PositionJointInterface</hardwareInterface>
  </transmission>
Then I found the robot in the gazebo seems won't be affected by gravity (seems like turn g from 9.8 to 0.5) .. very strange..
However, if I remove part:
</actuator>
Then the robot in the gazebo will be like in the real environment (which means g is 9.8)
I try to search via google but failed.
Does any one know why?
Thanks very much!
Asked by ZQSHI on 2017-07-22 01:42:39 UTC
